| Author |
Message |
Randy Administrator.
Thanks: 18 Thanked 33 Times in 15 Posts
Posts per day: 1.22 Location: Ajax, Ontario, Canada
Posted: Sun Aug 22, 2010 8:07 pm Post subject: Camber Plates |
Do you need Camber-Caster plates plates Many Honda's use McPherson struts, only one of the three alignment settings toe can be adjusted. For high performance use, the ability to adjust camber and caster is desirable as well, particularly on the front suspension. Camber-caster plates provide these adjustments, and usually replace the upper mounting and bushing at the top of the fender well where the strut rod is connected to the body.
Camber is the amount the top of the tire leans inward or outward in comparison to the bottom of the tire with the tires straight ahead. If the wheel leans inward at the top, it has negative camber. If it leans outward at the top, it has positive camber. The measurement is made in degrees and minutes.
Most Honda's will work better under hard cornering with negative camber. By leaning the wheel inward at the top, the bottom is leaned outward. This outward tilt where the tread meets the pavement helps resist tire-sidewall rollover, keeping more of the tread in contact with the road and increasing its cornering traction. Looked at another way, it gives the tire a head start against body and tire roll.
The disadvantage of negative camber, particularly in great amounts, say, more than one degree, is that tire wear will increase (on the inside edge) as the car is driven under normal conditions. Also, the car may dart when it encounters different surfaces from side to side, like running through a puddle with one side of the car.
Caster is hard to visualize on a car because of the links, arms and struts that make up the suspension. But, using a motorcycle as an example, think of the front forks and how the bottoms of the forks are ahead of the tops. The more the forks are leaned forward at the bottom, the greater the caster. The result when the handlebars are turned is that the bottom of the tire leans outward.
The alignment of car suspension components results in the same effect. The more the wheel on the outside of a corner is turned, the more the bottom of the tire leans outward. By adding more caster this effect is increased, again helping the tire tread to keep full contact against the road. Additionally, more caster increases the car's resistance to wandering when being driven straight, and increases the self-centering action of the steering wheel. The disadvantage Camber-Castor plates allow adjustment of front suspension alignment beyond that allowed by the stock components. Generally, toe is the only adjustment that can be made.
For a zero setting, the tire/wheel assembly is in the exact vertical position or perpendicular to the ground.
Camber : The inward or outward tilt of the tire/wheel assembly. This angle is measured from a true vertical line, perpendicular to the ground. A tire/wheel assembly that is tilted outward at the top is considered to have Positive camber. While a tire/wheel assembly tilted inward at the top, displays Negative camber.
Effects of negative camber : negative camber can be used to improve the handling of a vehicle. A setting of 1/2° negative on both sides of a street car will improve cornering without affecting tire life greatly. This negative setting compensates for the slight positive camber change of the outside tire due to vehicle roll, thereby allowing a flatter tire contact patch during cornering. Excessive negative camber wears the inside of the tire and similar to positive camber, it can cause wear and stress on suspension parts.
Effects of positive camber : results in a dynamic loading that allows the tire to run relatively flat against the road surface. Positive camber also directs the weight and shock load of the vehicle on the larger inner wheel bearing and inboard portion of the spindle rather than the outboard bearing. Positive camber in moderation results in longer bearing life, less likely sudden load failure, and as a side benefit, easier steering. Excessive positive camber wears the outside of the tire and can cause wear to suspension parts such as wheel bearings and spindles.
The spherical bearings are soft brass. The camber plates were plasma cut from 1/4inch steel plates. Adrians model used to design the plates to move inwards and back along a linear line. The spherical bearing is held in by a welded top, and the bottom traps the bearing using a inside c-clip. The rears are adjustable for camber only.
Camber-castor plates allow adjustment of front suspension alignment beyond that allowed by the stock components. Generally, toe is the only adjustment that can be made.
This one on the left is from A-T Engineering, for a 1200 Civic.
The one on the right differs mainly in attachment and is installed on George Cleveland's 1200 Civic. In addition to adding adjustments to the cars, these plates also attach to the strut rods with spherical bearings. These bearings replace the less precise synthetic rubber bushings that are stock.
Caster : The forward or rearward tilt of the projected steering axis from true vertical, as viewed from the side. This line is formed by extending a line through the upper and lower steering knuckle pivot points. For vehicles with front control arms, visualize the line extending through the upper and lower ball joints. Caster is always viewed from the side of the vehicle. When the upper pivot point is rearward of the lower pivot point, caster is positive. If the upper pivot is forward of the lower pivot point, caster is negative. When the two points are straight up and down from each other, the caster is zero. Caster is not a normal tire wearing angle and is used as a directional control for stability and steering return ability. Caster effect is necessary so that the load of the vehicle is "carried" through the steering axis line formed on the upper and lower pivot points.
Effects of positive caster : positive caster promotes directional stability, however, excessive positive caster can cause two problems. The first is that excessive caster will cause a high level of road shock to be transmitted to the driver when the vehicle hits a bump, etc. The second problem is that a tire/wheel assembly with positive caster has a tendency to toe inward when the vehicle is being driven. If one side has more positive caster than the other, this causes it to toe inward with more force than the other side. This will cause a lead or pull to the side with least amount of positive caster.
Effects of negative caster : a vehicle with negative caster will have a tendency to be easier to steer but will lack directional stability. It is also affected by any road surface variation such as small road irregularities or bumps. With the point of load pushing the tire along (negative caster), any bumps or road irregularities which are encountered have a tendency to immediately affect directional stability and vehicle handling. |
| Back to top |
Ad Man Administrator
Posted: Sun Aug 22, 2010 8:07 pm Post subject: Sponsor Links Advertisement |
| Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You can download files in this forum
Powered by phpBB © 2001, 2005 phpBB Group First Generation Honda Civics' is not in anyway affiliated with or endorsed by Honda Motor Co.,Inc
Established January 2000 :: Formerly 1stgenofdurham
