Suspension Time
First Generation Civic Discussion Board: Second Generation Civic Discussion Board: Suspension Time
Top of pagePrevious messageNext messageBottom of pageLink to this message   By stormkingxx (63.23.97.70) on Monday, September 17, 2001 - 09:48 pm:
Now that my engine work is done ,I am looking at improving the suspension and aerodynamics. dobiperformanceonline.com has some springs that will drop the car an inch ,great(and the have an air dam for early civics too!). KYB has a GR2 strut tower and cartridge , fine. But in order to make these mods work together , I'm thinking strut tower brace on the front and rear ,....if possible . Any suggestions as to what I might be able to put on. Also some suspension bushings that are polyurethane/urethane would be nice. Comments anyone..??
that's-> http://www.dobiperformance.com/open.html
Top of pagePrevious messageNext messageBottom of pageLink to this message   By quikrick (63.204.16.66) on Tuesday, September 18, 2001 - 10:15 am:
Addco still lists the lower (under car) anti sway bars for the front and rear, they have urethane bushings available too. Not cheap!
With the Dobi springs, KYB struts and the sway bars, I think you will be set. If you want the strut tower braces, you will probably have to have them custom made... these cars are just too old for most aftermarket parts. Good luck!
Top of pagePrevious messageNext messageBottom of pageLink to this message   By stormkingxx (63.23.64.149) on Tuesday, September 18, 2001 - 04:19 pm:
Sounds good, thanks
Top of pagePrevious messageNext messageBottom of pageLink to this message   By quikrick (63.204.16.66) on Tuesday, September 18, 2001 - 04:39 pm:
BTW I have used Dobi springs (1st gen Accord). Very nice upgrade.
