| By Jonny (142.36.217.199) on Friday, July 08, 2005 - 10:02 am: |
I used Prelude ones for my RS carb setup... I can't remember the exact year but it is the Prelude that has the dual carbs very similar to the RS carbs... I had to drill a new hole as they have a different bolt pattern... one stock hole lines up so just had to drill one new one.
Jonny
| By Hugh Johnson (Oneson1) (144.138.198.254) on Friday, July 08, 2005 - 07:04 am: |
I believe that they are also a motorcycle part, but the bolt pattern to the manifold is different, easily fixed I believe, find bikes that have the same type of carbies. Not nessesarily Honda either!
hugh
| By John S. (207.160.168.243) on Thursday, July 07, 2005 - 02:01 pm: |
Hi Jim,
Those are hard to come by. I would look up the Japanese RS websites...there are at least two. Those guys might be able to help you find a set, but if you do , I'd order two sets not just one. I think those carbs were only spec on Japanese RS models, maybe not exported anywhere else. By the way, the British Triumph Acclaim and Civic S models 82-84 used very similar dual carb setup, but I don't know if they used that part, or something close enough to it to work.
| By Jim (Drzoom) (70.49.61.125) on Wednesday, July 06, 2005 - 11:32 pm: |
Nothing?
| By Jim (Drzoom) (70.49.61.240) on Monday, July 04, 2005 - 05:31 pm: |
I need the part number for the RS carb boots. Rubber mini manifolds from aluminum manifold to carb,.... And were you order them from. I`m looking for a Honda Car/Motorcycle dealer available part.
