| By bomohymns (210.186.110.102) on Wednesday, September 17, 2003 - 08:16 am: |
my civic is using 1.5L engine with EC code. Can somebody gimme the spec for that engine?....
| By ozzy (203.206.51.250) on Saturday, September 06, 2003 - 07:11 pm: |
So there are differences between early/late EL engines?
Is one better than the other (in terms of reliability & esp. for making power)?
| By John S. (205.188.209.51) on Saturday, September 06, 2003 - 04:03 pm: |
I think you need a 1751 crank...check to see if the bore spacing on the EL motor is even or not, I think the journals are more widely spaced on the EL as opposed to the EG-EM block. If so you want the early 1751 crank, 79 to 80, 49 state crank to fit the Civic trannys, or the 81-82 crank to fit the Accord and Prelude trannys, all 1751 rods are interchangeable.
| By Colby (216.104.65.202) on Saturday, September 06, 2003 - 10:18 am: |
My guess is yes on the '79-81 blocks (with matching rods).
| By ozzy (203.206.102.225) on Saturday, September 06, 2003 - 12:09 am: |
Would anyone be able to tell me if it would be possible to swap the crank and rods from an EG(1599cc non-CVCC from '76-'78 Accord) engine into an EL (1602cc non-CVCC from '79-'83 Accord/Prelude) engine?
All things going well this would result in a bore/stroke of 77x93 (~1732cc), which is pretty darned close to the USDM EK1's 77x94 (1751cc).
