| By Glenn Biscan (211.28.166.211) on Saturday, September 13, 2003 - 07:28 pm: |
next run will be on cam so you will be able to watch it from inside. i have a tacho set up where the camera is going to be so you can see the high RPM's
Should be ok.plus i will have external view as well
http://biscan.cjb.net
| By Dave (209.226.249.111) on Saturday, September 13, 2003 - 09:52 am: |
7500 rpm dump wow thats sounds brutal!
| By kiwi (210.55.81.16) on Saturday, September 13, 2003 - 02:59 am: |
read through the board via the keyword search and you will see not only writeen but graphical evidence of thats the civics are capable of (thats depending on our budget)
i own a ford escort sports 1600cc, and my 1300cc civic leaves it for dead all over both performance and handling wise
| By Glenn Biscan (211.28.166.211) on Saturday, September 13, 2003 - 02:57 am: |
when i was @ the drags was doing 7000rpm dumps and i had no problem. with 5spd gearbox from en1 wagon
This time i will have a 1200 4spd with a locked diff. ill let you know if it breaks @ 7500rpm dump
| By Alexkayden (Alexkayden) (203.113.195.157) on Saturday, September 13, 2003 - 02:39 am: |
How many of you have had front wheel drive problems, because I have heard you can't do drag racing and burnouts and so on with a front wheel drive car.
to be more specific I am looking at buying a ford escort two door or a doing up the 1977 honda civic, I want it to handle well, use it for drag racing up to about a 13 or 14 second quarter mile car, a little bit of hard acelerating around the streets (urban rally) how much can the little hondas take.
