| By Adrian Mifsud (203.51.131.39) on Monday, September 15, 2003 - 02:32 am: |
Thanks again I will go and get a pair of reco'd CV's on the weekend
| By Adrian (Evocivic) (165.228.11.61) on Sunday, September 14, 2003 - 04:25 am: |
Yeah, an out of round tyre will also do it. Get them balanced and you'll find out if one isn't round.
Reco'd CVs should be around $100 - $150 each. They usually only redo the outer CV as the inner ones don't wear much.
Top strut mounts are not easy to come by new. All old ones are a bit cracked and it makes no difference unless they are actually broken.
| By Adrian Mifsud (203.51.165.168) on Sunday, September 14, 2003 - 01:09 am: |
i rotated the tyres on the left hand side front to back and it helped but there is still a little vibration. I raised the front of the car up on stands before i rotated the tyres and i think the tyre that was on the front not rotating smoothly. i think there is a lump in the tyre. I might change cv joints and then have a look at the bushes. Do you know how much the cv's are per side, and do you know if i can get the upper strut mounts for the front as they are cracked. Im from melbourne australia
Thanks again
| By Adrian (Evocivic) (165.228.11.61) on Saturday, September 13, 2003 - 03:12 pm: |
I'd be looking at wheel balance, balljoints and bushes as well as the CVs.
| By Adrian Mifsud (203.51.165.168) on Saturday, September 13, 2003 - 02:15 pm: |
I have a 75 Civic sedan 1500 non cvcc and when I drive it on the freeway at 90km/h or more the car vibrates like crazy. I know it has bad cv joints as the make a hell of a noise when turning either way. Could this be the problem or can anyone think of anything else
Adrian Mifsud
