| By kiwi (210.54.65.72) on Thursday, September 18, 2003 - 08:18 pm: |
yea i found the front crome wouldnt line up with the light surrounding ones quite, so i took a small ball hammer and tapped down where the hunges attach to the front so they are sunken in a little, made it look a little more into place. problem i had with the bonnet was it lined up perfectly alond the windscreen side but looked out of place with the drivers guard, so i replaced the guard and now it looks odd with the passengers one, but sourcing EB3 parts here in NZ is getting difficult as they nolonger sit at the wreckers for years, they are 1st in line for crushing due to our stiffening road laws
| By Glenn Biscan (211.28.166.211) on Thursday, September 18, 2003 - 02:54 am: |
did u find your bonnet wasnt perfectly even and was a litte high @ the front ?
cause thats how my bonnet is. lol
but unless your looking i suppose you wouldnt notice
| By kiwi (210.54.64.134) on Thursday, September 18, 2003 - 02:33 am: |
i had the same set up Glenn, i cut a small snip out where the hinge hung on either side and painted the hinge black, unless ur really looking it was almost un-noitacable
| By Glenn Biscan (211.28.166.211) on Wednesday, September 17, 2003 - 02:40 pm: |
im asking the same question of how to mount a grill from a different perspective.
i have a 76 model civic and have put the 79(eb3) bonnet on.
i used the existing hinges and i have now found that the grill wont fit due to the hinges hitting it. im worried that it may look really silly if i take out a section of the grill
Glenn
biscan.cjb.net
| By Justin (207.102.0.6) on Wednesday, September 17, 2003 - 09:37 am: |
You will need the head light bezels from the '77 or earlier 1200, aswell as the lower chrome strip that fills between the bezels and runs along the lower portion of the grill, the olny problem with the set-up is that the turnsignals on the earlier cars are designed to mount thru the chrome lower strip
If you can find a set of the early wagon turnsignals (pre '78)they actually mount off of the grill, and doing this it will cover up the holes in the strip
But you will also want to then change your front bumper to a pre '78 aswell..
| By joe Blow (67.164.38.237) on Tuesday, September 16, 2003 - 08:18 pm: |
Ok i have a 79 1200 civic and i just got a hunnycomb grill and i noticed it dose not fit dose ane one know how to make it fit???
and i also need another 71 to 73 turn signal if you guys know what i mean
