| By R.Leigh (Kiwi) (210.54.64.11) on Saturday, October 18, 2003 - 06:55 pm: |
EN 1300 is a bolt up in a civic 1200, apart from having to make a new arm for the top torque rod (which isnt hard),the 1200 axles fit right in and hte trans a direct bolt with no flywheel shaving needed
I have one in a 1976 1200 and the only problem i found was the exhaust heat shield come out at the wrong angle to the radiator.
Plus u can put the 1300 EN electronic dizzy in, makes driving a bliss compared to points
| By Paul (216.113.209.132) on Friday, October 17, 2003 - 03:39 pm: |
If you go with the EN 1300 I believe you can use your stock 1200 axles, the 1300 tranny, no other mods required.
But I would double check with Justin though. ;)
While your at it you might as well go with a 4x 100 swap just take the frount cv outers from the donor car & redrill the rear drums.
Later
| By Ron0RoundSue (152.163.253.2) on Saturday, October 11, 2003 - 10:44 am: |
Paul
Maybe the motor will bolt in but what about the trans & axles? Any other mods I'll need to know about?
Sue
| By Paul (216.113.209.125) on Friday, October 10, 2003 - 01:24 pm: |
Bolt in's
an early Accord 1600.
a 80-83 civic (EN)1300.
an early Prelude 1800.
They're cheap & has more power than the stock motor.
| By R.Leigh (Kiwi) (210.54.65.232) on Thursday, October 09, 2003 - 07:10 pm: |
http://www.civic1200.com/discus/messages/1/5343.html?1065488480
maybe some help?
| By Run0RoundSue (205.188.209.107) on Thursday, October 09, 2003 - 06:01 pm: |
I just bought a 1977 Civic 1200 hatchback last week. The body is in excellent shape but the motor is seized so I'm looking to put something in it. I don?t want to do a lot of changes. What I?d like to know is will a 1500 CVCC engine work without having to do a bunch of stuff to it. I mean will the manual trans bolt up to it? Will the motor mounts work? The axles should work. Anything else I should know? ANY help you guys can give me would be great.
Oh and does anyone know where I can get a motor for it?
Sue
