| By Mr. Dillon (Oldskol) (66.123.54.78) on Tuesday, October 28, 2003 - 07:16 am: |
I have removed the screws and all wires ..yes it is the knob style din radio..i can shake it around with about a 1" or 2" inch of movement but seems to be held by something... i.e. air duct from fan unit . or other unit ... Thanks for the help !!
| By jake thomas hilliard (Classucivic) (64.146.131.193) on Monday, October 27, 2003 - 04:28 pm: |
is it a shaft style of single din
shaft style is a knob deck which is generally secured using bolts behind the knobs and sometimes a bolt in the rear with a peice of metal flang if it is a single din then there is a sleeve around the deck and there are usually tabs tht are bent up to secure the head unit in place once those are bent back down you will be able to remove it dont forget to disconnect the wiring harness
| By Mr. Dillon (Oldskol) (64.12.96.44) on Sunday, October 26, 2003 - 10:53 pm: |
hello guys I just picked up a 1976 cvcc 5speed..runs good ,needs smog..I will have pictures of elenor soon, anyway i started tinkering around with it today, and got the radio lose but couldnt get it out of the dash . do i need to remove the dash to get it out ..it is a audiovox so i guess it is not the stock unit ..but it is dead ..thanks for any help in advance ...
