| By Don (199.2.139.223) on Tuesday, October 28, 2003 - 12:05 pm: |
Its a stock 1974 1200 master with the 1973 Manual brake plate and rod. They are easier to get from OZ than the USA. I have only seen one in the USA.
| By Glenn Biscan (211.30.144.154) on Tuesday, October 28, 2003 - 01:06 am: |
mmm if that twin reservior is any better than stock and i dont have to use a booster than that might be the way to go.
just that there is hardly any braking power in my car, and the honda that i drove with the boost is really awesome, stops like a real car.
if i do a brake rotor and caliper change to larger will the be better than just fitting a booster?
| By farenheight101 (24.69.255.203) on Monday, October 27, 2003 - 10:42 pm: |
That the wagon master cylinder? Is that any better than the 1200 master cylinder with only one resevior?
| By Don (199.2.139.148) on Monday, October 27, 2003 - 05:34 pm: |
| By Kurt (142.179.39.216) on Monday, October 27, 2003 - 02:41 pm: |
I don't believe Don is running a booster on his race car either.
| By farenheight101 (24.69.255.237) on Monday, October 27, 2003 - 12:46 pm: |
well I figgured that these things are soo light that you wouldn't need the booster but strong legs (as I have...not to brag, hehe). How do you recurve the distributor? just take out all the vacuum related stuff and plug or stop anything that won't be in use?
| By Zippy (Zippy) (67.106.175.3) on Monday, October 27, 2003 - 07:23 am: |
I don't run a booster. You should drive your car with out the booster and see if you really want it before you cut any holes in your manifold.
| By Bryan (66.32.126.64) on Monday, October 27, 2003 - 06:23 am: |
I would have the dizzy recurved so that you don't need the vacuum advance. As far as the power brakes go, the booster does not have a constant vacuum pull on the engine, so the vacuum port could just be on 1 runner. The idea of taking it off of all the runners for a balanced "leak" is a great idea, but just not very easy to do without making the plumbing look horrible.
There are electic vacuum pumps that would also work very well. Buick grand nationals, and I believe late model camaros and firebirds have them as well.
| By Glenn Biscan (211.30.144.154) on Monday, October 27, 2003 - 02:21 am: |
yeah i would like to know as well cause i have the same setup
and the booster is about 2 go on
| By farenheight101 (24.69.255.237) on Monday, October 27, 2003 - 12:28 am: |
Anyone know what I can do about vacuum for the brake booster and vacuum advance because the dual dellorto manifold doesn't have any vacuum ports. I can't see drilling into it unless you tap into each runner and then merge those hoses into one port for vacuum so the pressure is even.
Also I heard of using a vacuum pump from an early 80's Chevy Cavalier Cadet, and also theres this electric car parts company that make a vacuum pump for an elecric car brake booster, but all these pumps are too expensive. What to do...
