| By OKIEFAB (152.163.252.229) on Thursday, October 30, 2003 - 07:27 pm: |
TO MANY RULES IN CALI HERE IN OKIE DOKIE THEY DID AWAY WITH OUR STATE INSPECTION LAWS A COUPLE OF YEARS AGO
| By Jerry (Shifterkart) (68.7.92.96) on Thursday, October 30, 2003 - 05:39 pm: |
can the 2nd gen civic 1500 motor drop right in to first gen civics? what kind of modifications are needed to make it fit?
| By Kabuto (Kabuto) (68.116.85.75) on Thursday, October 30, 2003 - 05:22 pm: |
The current age for the smog exemption in CA is 1974 and older. The year will jump to 1975 on Jan 1st. I know that the BAR regs say 30 years, but the DMV is issueing registrations for the 74s as exempt, I just renewed mine and found that out for sure. A local smog shop showed me a pritout from the BAR that said the same thing, I just thought that there was an error, evidently it was right. Good luck!
| By Quikrick (Quikrick) (63.204.16.66) on Thursday, October 30, 2003 - 04:57 pm: |
Crap... I meant 1973 and earlier.
| By Quikrick (Quikrick) (63.204.16.66) on Thursday, October 30, 2003 - 04:55 pm: |
As far as smog goes... You had better check with the DMV. I'm pretty sure that only '74 and ealier are exempt. But I think that it might have to do with what county you live in.
| By Jerry (Shifterkart) (68.7.92.96) on Thursday, October 30, 2003 - 03:48 pm: |
i know this question is probably asked hundreds of times but.. what is the most easiest swap to do on a first gen civic with little or no modification at all. i was told a 75' will not be required to smog.. in california, is this true?
