| By felipe casanova (200.30.232.120) on Monday, December 29, 2003 - 10:00 pm: |
thanks guys...the trouble is that when my fan comes on..doesn`t even sound...with luck only spins..but i will try it anyway..
| By bruce (67.200.12.221) on Monday, December 29, 2003 - 04:49 pm: |
felipe, unplug your thermosensor at the bottom of the radiator, take a wire and jump the connectors, if nothing else grab a fan off a newer honda, take the motor off and wire it into the original fan frame.
| By Ted (63.224.195.169) on Monday, December 29, 2003 - 01:18 pm: |
Yep, clean up the sensor and remove any crud in the connectors. Make sure the fins are not binding with anything, check for play in the fans drive shaft. Test for voltage in the wires. If you suspect the motor is shot, grab a used one at a yard.
| By felipe casanova (200.30.232.120) on Monday, December 29, 2003 - 11:40 am: |
i tried my fan and is like s...t anybody help please? anyway i`ll try one last time the wires
| By Hondaparts (63.166.190.64) on Monday, December 29, 2003 - 07:29 am: |
Are you sure its the fan, it could be the sensor or the wires always break.
| By felipe casanova (200.74.70.98) on Sunday, December 28, 2003 - 08:10 pm: |
hi guys wishing to you all a happy new year i want to ask something about the fan...my actual fan is working bad and im gonna replace it with a new one but...anybody knows if i can put other fan that cool more and don`t be too expensive? maybe from an accord or from an special company?
please help me!
