| By Jonathan (68.193.10.141) on Friday, January 16, 2004 - 08:07 pm: |
10.3 kgm @ 3,500rpm ~ 74 lb-ft
| By CVCC x 2 (64.229.51.68) on Friday, January 16, 2004 - 07:57 pm: |
I am just looking at the brochure for the Canadian 83 Civic and the EN1 is listed as follows;
1,335 cc
72.0 x 82.0mm/2.83 x 3.23" bore & stroke
61 hp @ 5,500 rpm
10.3 kgm @ 3,500rpm (not sure what that is in lbs/ft)
8.4:1 compression ratio
Hope this helps
| By H (24.67.134.220) on Friday, January 16, 2004 - 07:11 pm: |
The EN came in the 80-83 Civic 3dr,5dr and Wagon.The EN was not available in the US.I think they produce about 65hp.
| By jms (66.242.1.135) on Friday, January 16, 2004 - 06:35 pm: |
how many HPS from EN1??
What did EN1s come on, what years?
| By Jacob (67.170.131.249) on Friday, January 16, 2004 - 10:13 am: |
The heads are different. The EB3 head has a larger combustion chamber and larger valves so it runs domed pistons to get a decent C/R. The EB1 has a 70mm flattop pistons while the EB2/3 have 72mm pistons (EB2 flattop, EB3 domed).
The EN1 is an EB3 with an 82mm stroke instead of a 76mm stroke (both have 72mm bore). An EN1 is basically an EB3 with an EJ1 crank/rods, the factory just did the stroker conversion for you.
Pretty sure everything's interchangable between an EN1 and an EB3.
| By Xavier (M267) (24.82.105.121) on Friday, January 16, 2004 - 08:34 am: |
Whats the difference between an EB1 and an EB3?
| By mo (80.217.184.184) on Thursday, January 15, 2004 - 01:58 pm: |
en1 .. definitely ...
| By Goodriver (Goodriver) (24.82.105.121) on Tuesday, January 13, 2004 - 06:05 pm: |
what do you think of the en1...and the eb's
