| By lazy (165.228.57.19) on Saturday, April 24, 2004 - 08:48 am: |
and how is a flaring tool going to help if I just want to clamp the hose to the pipe? The stock fuel lines have a slight rib where the hose connects.. how do I do that?
| By lazy (165.228.57.19) on Saturday, April 24, 2004 - 08:28 am: |
what diameter pipe should I use? I'm hoping to eventually switch to efi and use the original fuel line as the return as many others have. so with that in mind would 8mm be large enough?
| By Hugh Johnson (Oneson1) (144.138.198.168) on Tuesday, January 20, 2004 - 05:44 am: |
Put solid fuel lines through the cabin....I repeat-Put solid fuel lines through the cabin. Do not use rubber, neoprene, Gods special plastic or anything else but well mounted (every 6") steel, copper or braided fuel lines anywhere near a human body, Firewalls are called that for a reason, and I'm not joking. Flexible fuel lines in the cabin are as clever and safe as hand whittled, soft pine brake pads. Just dont.
| By Glenn Biscan (211.30.144.154) on Monday, January 19, 2004 - 10:31 am: |
i just use rubber fuel hose its easier
| By bruce (68.156.75.29) on Monday, January 19, 2004 - 09:42 am: |
any autoparts store for the line, pipe bender, flaring tool, nuts and compreesion fittings....or find someone that has a bunch of spare fuel lines laying around.
| By lazy (210.10.240.118) on Monday, January 19, 2004 - 05:58 am: |
Can anyone offer a n00b's guide to making your own fuel lines? Questions that come to mind are:
what tools do i need?
what sort of pipe to use?
where can i buy all this stuff?
thanks in advance
