Engine Specifications for Canadian EN1 ?
Civic1200 Discussion Board: : Engine Specifications for Canadian EN1 ?
By glen (203.109.250.65) on Wednesday, January 21, 2004 - 11:09 pm:
Charles
How much would you want for the car?
By H (24.67.134.220) on Wednesday, January 21, 2004 - 09:33 pm:
Hey Randy
non turbo ER
1231cc
66.0 x 90.0
67hp @ 5,500 rpm
72lbs @ 3,500 rpm
10.0:1
turbo 1 ER
1231cc
66.0 x 90.00
100hp @ 5,500 rpm
108lbs @ 3,000 rpm
7.5:1
turbo 2 ER
1231cc
66.0 x 90.00
110hp @ 5,500 rpm
118lbs @ 3,000 rpm
7.6:1
I also found this ???
EN1
1335cc
72.0 x 82.00
68hp @ 5,500 rpm
74lbs @ 3,500 rpm
8.4:1
I noticed the EF is already on your chart.That just leaves the EC EG and EL.I know I have the specs on the EL somewhere.Not sure about the EC EG.I'll do some searching and get back to you.
By Shreck (66.185.85.79) on Wednesday, January 21, 2004 - 06:50 pm:
The City Turbo motor is an ER? 1237cc, @ 100hp, Compression 7.5.1 does anyone know what the rest of the specs are bore stroke and torq. From 1981-1987
Dave thanks for pointing out the error on the 5-speeds.
Dave if you come across the info on these engines EC EF EG and EL
By H (24.67.134.220) on Wednesday, January 21, 2004 - 04:52 pm:
That is a cool site!Thanks for the link Charles.
By Charles (144.138.156.159) on Wednesday, January 21, 2004 - 04:31 am:
Actually, there was a Jap EW that was cvcc. My brother owns one! They also came out with EFI. The ECU also runs the CVCC ER Honda city turbo motor quite happily. There are derivitives of engines and then derivatives of the derivatives! Jap cvcc efi version came out with 100hp.
http://www.honda.co.jp/HOT/ModelData/civic/cv3-k-309/25i_sy.html
BTW if anyone in Aus (SA) wants a complete import cvcc EW 84 model 25i civic with slight frontal damage for next to nix let me know. They are a very quick little motor with 100hp straight out of the box.
By H (24.67.134.220) on Tuesday, January 20, 2004 - 09:42 pm:
Whoooppsss.Yes you are correct Adrian.Thats a typo.Both the EV and EW are non cvcc engines and are of the "crossflow design"
By Adrian (Evocivic) (165.228.11.61) on Tuesday, January 20, 2004 - 09:38 pm:
The RS had a 5-speed and it was around in 74-75.
By H (24.67.134.220) on Tuesday, January 20, 2004 - 09:31 pm:
Also,in the "Additional Information" it states "The 75-79 CVCC was the only first gen engine equipped with a 5spd transmission (the 1200 would not be able to pull the gear ratio properly)"this is incorrect.In non US markets the 78-79 1200's could be had equipped with a 5spd trans.(This model had the deluxe gauges,but did not have the wood wheel or wood shift knob).And of course the Specail X which also had the 1200 and a 5spd.
By Adrian (Evocivic) (165.228.11.61) on Tuesday, January 20, 2004 - 09:27 pm:
The EW is not CVCC (at least the Australian delivered EW2s aren't).
By shreck (24.112.121.191) on Tuesday, January 20, 2004 - 09:26 pm:
Thanks Dave that would be a great help.
Anyone else know of swaps that have been done that should be on the list?
By the way if you have not been to the site for a while there have been a lot of changes.
Sorry about the ads but I have to do it to help pay for the site, as I am still paying for the old one still. At leat they are not pop up ads.
http://www.1stgencivic.com/index2.html
I tried to work it in with the theme of the site and might help you out as well.
Check out the buy and sell, there are about 100 + items listed there every day.
http://www.1stgencivic.com/buy_sell.html
Any bid won through this site helps pay to keep the site alive. There won't be much, but every little bit helps. Same goes for the other Ads on this page.
By H (24.67.134.220) on Tuesday, January 20, 2004 - 09:08 pm:
I think your list should include the EC EF EG and EL for sure.I think I have the specs on these engines somewhere I will see what I can find for you.
By H (24.67.134.220) on Tuesday, January 20, 2004 - 08:57 pm:
EB1 73-74 1169cc non cvcc Civic 1200
EB2 75-77 1238cc non cvcc Civic 1200
EB3 78-79 1238cc non cvcc Civic 1200
EC 75-79 1487cc non cvcc Civic wagon
ED 75-79 1487cc cvcc Civic wagon
EF 76-78 1600cc cvcc Accord
EG 76-78 1600cc non cvcc Accord
EJ 80-83 1335cc cvcc Civic
EK 79-83 1751cc cvcc Accord/Prelude
EL 79-83 1600cc non cvcc Accord/Prelude
EM 80-83 1487cc cvcc Civic
EN 80-83 1335cc non cvcc Civic
ER 80-83 1238cc cvcc City
ES 83-85 1829cc cvcc Accord/Prelude
ET 85-86 1829cc cvcc Prelude
EV 84-86 1342cc cvcc Civic
EW 84-86 1488cc cvcc Civic
EZ 85-86 1829cc cvcc Accord
By shreck (24.112.121.191) on Tuesday, January 20, 2004 - 08:30 pm:
Thanks Dave for the info.
Was this the only one missing from the list that you could see?
By H (24.67.134.220) on Tuesday, January 20, 2004 - 05:24 pm:
1980-83 EN1
1,335 cc
72.0 x 82.0mm/2.83 x 3.23" bore & stroke
61 hp @ 5,500 rpm
74 lbs @ 3,500rpm
8.4:1 compression ratio
By shreck (24.112.121.191) on Tuesday, January 20, 2004 - 05:10 pm:
Does anyone know what the Engine Specifications are for Canadian EN1. Was this motor used from 80-83?
Any help would be great.
http://www.1stgencivic.com/enginechart.htm
