| By 79EK1 (79ek1) (63.195.80.15) on Sunday, March 07, 2004 - 11:51 pm: |
Kurt, the MSD 6AL I hooked up to my Accord electronic ignition works fine with the stock tach. With the MSD, I hooked the blue tach wire to a white one from the 6AL box, and not the negative post on the coil. Which Mallory module are you running? I might be able to help, if I know which wiring diagram to look at on Mallory's website. Did you ever get the Accord ignition installed on your car? Dan
| By Kurt (142.179.34.133) on Sunday, March 07, 2004 - 10:15 pm: |
For those of you that run aftermarket modules how did you make out connecting the factory tach?
The reason I ask is that I'm running a Malory but have not been able to wire up the factory tach, wondering if I need the adapter part.
