| By bruce (66.20.228.226) on Wednesday, March 24, 2004 - 05:36 pm: |
if all else fails, put your jack under it to put enough pressure on it so it won't turn.
| By jcart (64.108.205.83) on Wednesday, March 24, 2004 - 03:44 pm: |
Thank you for the quick response. I will give it a try.
| By farenheight101 (24.69.255.203) on Wednesday, March 24, 2004 - 03:24 pm: |
I'd take a thread file to it, make it spin on with your fingers. They don't need to be tight...just snug, then you put in the cotter pin in to hold it snug.
| By Adrian (Evocivic) (165.228.11.61) on Wednesday, March 24, 2004 - 03:22 pm: |
Make sure the threads are clean and undamaged and the nut goes on easily when it is apart (clean with a tap and/or die as appropriate). Push the taper into its hole as hard as you can and screw the nut on. A rattle gun makes it easy
but the CV joint tends to get in the way.
| By jcart (64.108.205.83) on Wednesday, March 24, 2004 - 03:10 pm: |
I was wondering the best way to tighten the nut on the ball joint? on the lower arm. I try to tighten the nut and the whole ball joint turns. Thanks in advance.
-Jim
