| By Chaffneue (Chaffneue) (64.180.112.150) on Tuesday, March 30, 2004 - 08:15 pm: |
Yeah I saw the flat part.. guess I didn't use enough force.. thanks guys.
| By Knifeboy (142.173.4.227) on Tuesday, March 30, 2004 - 08:00 pm: |
I tilt mine to about 45 degrees then lift it straight up. Easy as that.
Jason
| By Andrew McPhee (Comox_Civic_78) (207.81.93.207) on Tuesday, March 30, 2004 - 07:10 pm: |
I just did that Sunday. There is actually a flat spot in the plastic bushing attached to the seat back, that when lined up with the slot in the top of the pivot housing will lift right out. Come to think of it, the flattened bushing might only be on the left side, because once I got that side out, I pulled the seatback sideways and the rest came right out.I never looked at the other side. Hope that helps.
Andrew
| By Chaffneue (Chaffneue) (64.180.112.150) on Tuesday, March 30, 2004 - 06:42 pm: |
Hey all.. I got the bottom part of the back seat out, but the top part of it swivels on a hinge. is there a trick to getting the bottom part out of the hinge? I tried every angle to get it out, but it's still stuck there.
