| By brown 1751 (144.134.55.202) on Wednesday, April 28, 2004 - 04:08 am: |
I paid about $10 each .(I had to remove the CV joints from the sharfts)
| By Max (Max) (67.162.184.219) on Tuesday, April 27, 2004 - 05:59 pm: |
Were thinking of doing the same camber job, but we think shortening axles will be horrific in cost! how much was it to get yours shortened?
max
| By brown1751 (144.134.52.4) on Sunday, April 25, 2004 - 09:01 am: |
Yes that head looks like my head
| By Kurt (66.183.137.163) on Friday, April 23, 2004 - 11:30 pm: |
Mine plugs are equally spaced as well. The motor is an 81
Pic (not mine)
I believe the 82-83 have the exhaust ports evenly spaced out. Whereas the head like mine is the same port spacing as the CVCC(1500).
| By brown 1751 (144.134.55.24) on Friday, April 23, 2004 - 07:08 am: |
The engine runs fine it revs to just over 6000rpm in all gears with no flat spots or anythimg like that.I dont know the jetting they are off some sort of alfa. I just put kits in them and tried then. I did have to fit 2.25mm needle and seats to stop fuel starvation on fast left hand corners.
The EK has a 77mm bore and a 94mm stroke. I use an early EL head and that has the spark plugs equally spaced.
| By lazy (165.228.57.19) on Friday, April 23, 2004 - 04:42 am: |
the EK has a 77x94 bore/stroke. The EL came out in two flavours: one with a bore/stroke combination of 74x93mm and a later version with a 77x86 bore/stroke.
I'm under the impression that the earlier engine has siamesed cylinders, so if my EL has spark plugs that are equally spaced apart, does that mean I have the later engine? Or is it the later engine with the siamesed cylinders?
| By Kurt (66.183.137.163) on Thursday, April 22, 2004 - 08:36 pm: |
I thought the crank and rods were the same btw the two motors.
So how does the car run/drive with the dual carbs. I run the EL motor (8 valve also) and have a dual Dellorto 40 set up for the car that has not yet been installed. Happen to know the jetting of the carbs?
| By brown1751 (144.134.52.17) on Wednesday, April 21, 2004 - 01:38 am: |
I will have to get my friend to come around with his digital camera
I uesd 81 civic lower arms. Nissan N13 strut tops. With shortend 81 civic drive sharfts. To get the neg camber.
I made the inlet manifold myself with 2 steel plates that i had laser cut and 4 short pipes then i welded it all together
| By 1300dx (68.98.112.113) on Tuesday, April 20, 2004 - 08:33 pm: |
Can you post a picture of your intake manifold? I've been looking for one!
| By Ted (63.224.195.169) on Tuesday, April 20, 2004 - 11:46 am: |
Hey Brown, can you snap a pic of how you got that nice camber up front.
| By brown1751 (144.134.55.158) on Tuesday, April 20, 2004 - 08:07 am: |
pick a part in melbourne for about $50
| By lazy (165.228.57.19) on Tuesday, April 20, 2004 - 07:38 am: |
nice
I'm in the process of fitting an EL into my civic. I eventually want to see if an EK crank & rods will fit my block.. where'd u get your engine from?
| By EK1751 (144.134.55.158) on Tuesday, April 20, 2004 - 06:47 am: |
I run an EK 1751cc 8 valve.With twin 40mm side draft dellortos.
| By lazy (165.228.57.19) on Tuesday, April 20, 2004 - 04:37 am: |
what sort of engine are you running?
| By brown1751 (144.134.52.32) on Tuesday, April 20, 2004 - 03:24 am: |
I've finally managed to get some pictures of my civic on here.
I enter sprints at Phillip Island, where these were taken.
Awesome track!!!!!!!
