| By chris ingham (Cingham) (207.69.139.156) on Wednesday, May 19, 2004 - 04:27 pm: |
k20 solves all power problems =)
| By Andrew Fatseas (203.63.44.193) on Tuesday, May 18, 2004 - 06:00 pm: |
Sounds like there's not much more you can do with the EB apart from turbo (assuming you've got the compression ratio up higher than stock).
There's a number of engine swaps you can do: EW2 from mid 80s civic is a good one as it doesn't weigh much more than the stock motor and hence doesn't disturb the handling.
| By evil eb2 (203.96.100.85) on Monday, May 17, 2004 - 09:59 pm: |
hey i was hoping you guys can help me i've got a 76" eb it's already got a set of dellorottos dhlb 35's,large cam,en pulleys,red line air filters,worked bottom end.
all this makes it a fast street eb and at the moment has been able to beat a r33 gts skyline and a vtec del sol crx, but i still need more power ive considered the er turbo conversion, but i'd like any thoughts on either using a turbo from a er or super charger from a 4age? any other ideas thanks joe, nz
