| By Chris Elder (211.30.173.156) on Wednesday, May 26, 2004 - 10:35 pm: |
yeah, i think ive got myself an oil cooler lying around somewhere...
thanks for the advice
| By lazy (165.228.57.19) on Monday, May 24, 2004 - 05:12 am: |
What radiator are you using Angus?
| By Adrian (Evocivic) (165.228.11.61) on Monday, May 24, 2004 - 05:02 am: |
You don't need that big a radiator. If you must find yourself an aluminium radiator for the tiny bit of weight you'll save, then find one that'll fit in the standard spot. Otherwise just get a 1500 3 core one and modify it to fit.
Then get yourself an oil cooler ... it'll do far more good than a big radiator.
| By lazy (165.228.57.19) on Monday, May 24, 2004 - 04:44 am: |
Thanks for the tip, I'll be looking into it
| By Chris Elder (211.30.173.156) on Monday, May 24, 2004 - 03:13 am: |
Civic is probably the only one im interested in because i dont even know what the hell a Jetta is
thanks anyway....
$5 radiator? awsome
| By Jacob (67.171.196.144) on Sunday, May 23, 2004 - 10:41 am: |
I've observed two radiators that will probably work. One is an aluminum radiator from a '92-'95 Civic, not sure what engine it specifically came with, I'm quite sure it came with the 1.5L. It's a nice tidy little 1-2 core aluminum radiator very close in dimensions to stock.
The other is from a '99 Jetta (1.8L N/T, I think). With the factory plastic end tanks it stretches the entire length of the front grill area with .5"-1" to spare. The inlet/outlet are on the correct side, and the height is almost exactly the same as stock. I picked up the Jetta one on Ebay for $5.00 (USD) in great shape.
| By Chris Elder (211.30.173.156) on Saturday, May 22, 2004 - 11:35 pm: |
yep glenn... I was planning just that...
I'm already using the Aluminium block of an EB1.. and I am looking out for an Aluminium Radiator (preferably a Honda) that would be large enough to cover the front grill area...? or maybe that isn't SO necessary... but definately aluminium.
This engine will be running probably as much stress as Adrian's Mugen Civic might've been...(max revs = 9000-10000 rpm)
At these rates, my car will need significant cooling....
Any ideas to keep my engine cool?
| By -Andrew Smit- (Cvcc_Wagon) (154.20.82.197) on Wednesday, May 19, 2004 - 09:30 pm: |
http://www.convert-me.com/en/convert/weight
| By Glenn Biscan (211.30.144.154) on Wednesday, May 19, 2004 - 12:24 pm: |
u can start by removing the sound proofing from all over the floor, take out every last bit of u dont need, spare tire, jack,
dont bother with the heater core for the effort it is to remove it and the functionality it has on a street car better to keep it
then you could start making heavy components out of aluminium e.g. radiator
| By Adrian (Evocivic) (165.228.11.61) on Wednesday, May 19, 2004 - 01:23 am: |
Don't forget that Australian Civics are quite a bit lighter than the US models. A manual Australian EB3 should weigh around 710kg, whereas a US one will weigh nearly 770kg.
| By Chris Elder (211.30.173.156) on Wednesday, May 19, 2004 - 12:50 am: |
no probs... i worked it out....
a bit heavier than my initial judgement of the car, but still lighter than most things on the road today
what are some methods in reducing the weight of this car? (but still being roadworthy)
| By Chris Elder (211.30.173.156) on Wednesday, May 19, 2004 - 12:44 am: |
why thank you...
i was not familiar to this ...
its always good to make a fool of yourself because kind people point u in the right direction hehe.
(pity its not in KILO's! for my convenience.)
after all... this is Australia we are talking about
hahaha nah, thanks anyway, i just gotta work it out now....
i guess ill have to wait for my old man to come home before I can work out how to convert it.
| By -Andrew Smit- (Cvcc_Wagon) (154.20.82.197) on Wednesday, May 19, 2004 - 12:28 am: |
*cough*
http://www.civic1200.com/discus/messages/3923/7079.html?1084945302
| By Chris Elder (211.30.173.156) on Wednesday, May 19, 2004 - 12:03 am: |
Does anybody know the weight of a 1979 Honda Civic (preferably Australian spec)?
thanks in advance.
