| By felipe casanova (200.90.212.200) on Tuesday, June 15, 2004 - 03:09 pm: |
dang nothing happens.......and i don`t know why the needle doesn`t fit tight on the hole!
| By Goodriver (Goodriver) (64.180.160.22) on Monday, June 14, 2004 - 05:46 pm: |
check the seal on the mixture screww...there should be a little seal ....clean the isndie where the mixture screw goes in..,..an you can check any vacum leaks....
| By Zippy (Zippy) (12.106.14.107) on Monday, June 14, 2004 - 06:20 am: |
It's not ignored it's just not understood.
| By felipe casanova (200.74.70.165) on Sunday, June 13, 2004 - 07:03 pm: |
mmm nobody read this
| By felipe casanova (200.74.68.153) on Tuesday, June 08, 2004 - 08:17 am: |
but what im saying is that even the original mixture screw doesn`t fit tight in the hole and instead of adjust the mix the hole sucks in the screw and leave it there, and don`t mix anything is just "there"
| By Kurt (66.183.150.217) on Tuesday, June 08, 2004 - 12:46 am: |
If changing the mixture screw is doing nothing than there is somethng else going on - not the screw itself. I am having a similar problem with one of my Dellorto's in that the adjustment is doing very little. Check for vaccuum leaks, clogs, etc.
| By felipe casanova (200.30.216.153) on Tuesday, June 08, 2004 - 12:25 am: |
hi guys...my question is: the stock keihin carb brings the mixture screw facing to the firewall, right? well i noticed that my mixture screw is not working! because the other day i turned full clockwise and the car didn´t stop or show signs of a lean mix, after i full opened it and nothing happened too. i go to my honda dealer and ask for a new mixture screw and i noticed that the one that i was using was just "there", i bought a new one and happened exactly the same thing that with the other one the screw doesn`t mixture anything is just there sucked by the air generated by the mixture screw hole, so right now im riding without mixture screw and the car is ok(no black smoke issue and with the mixture screw fully closed or opened lots of black smoke)...but if honda make a mixture screw we should use it right? please help me!!!!
sorry about the long question!
