| By luckyluciano2 (68.104.196.30) on Monday, June 21, 2004 - 08:57 pm: |
there is no cheap solution, however these guys
http://www.force-efi.com/ were confident that they could put one together for $1200-1500 range.
i spoke with them extensivly about it.
| By Andrew (203.63.44.193) on Monday, June 21, 2004 - 05:45 pm: |
Ok, you could buy a Canon DCOE manifold, TWM throttle body and injectors, aftermarket ECU etc etc etc, but who is going to spend that kind of money on an old EB series motor? I gathered the intention of the original post was to determine a cheap bolt on solution (which doesn't exist), as anyone serious about it would have already researched the alternatives.
| By Mike S (202.12.233.21) on Monday, June 21, 2004 - 04:04 pm: |
Roger - if you're talking about the manifolds for the DHLB32 or 35 then I wish you luck finding throttle bodies. There are many available to replace DCOE/DHLA 40 - 45 - 50 carbs, but the DHLB (or Weber DCOF) are physically smaller ( than these more common carbs and I have NEVER seen aftermarket throttle bodies in this size (and I've been looking for >10 years!).
Of course I'd be happy to be proven wrong......;-)
| By Zippy (Zippy) (12.106.14.107) on Monday, June 21, 2004 - 06:24 am: |
EuroCarb has manifolds for the 1200 in stock that fit Dellorto Carbs among others. I have seen fuel injection bodies that fit on that manifold out on the great wide internet somewhere.
| By Andrew Fatseas (203.63.44.193) on Sunday, June 20, 2004 - 09:47 pm: |
None, without fabricating an appropriate manifold etc.
| By DaRk (66.50.181.108) on Sunday, June 20, 2004 - 12:29 pm: |
Hi guys....What fuel injection will fit a '79 1200 engine...? Thanks.
