| By -Andrew Smit- (Cvcc_Wagon) (209.121.214.102) on Saturday, July 03, 2004 - 12:46 am: |
thanks, thats what i kinda figured. on a related note, where can i get a adjustable cam gear for an el/ek head. i know that with the next generation honda's aftermarket ones can be bought but i haven't seen any for the early ones
| By paul (24.80.190.37) on Friday, July 02, 2004 - 10:13 pm: |
When you shave the head, you move the pulleys together.
When this happens the teeth on the timing belt/chain shift. Also the total length of the belt required is less. but the tensioner hides this
If you shave it down far enough it would be like haveing the timing off by a tooth, on the cam gear.
Which is why a adjustable cam gear is preffered.
hope this helps
| By Shea Laking (Sheaman71) (66.185.85.79) on Friday, July 02, 2004 - 10:10 pm: |
In a word, yep.
Actually, I'd think this is more of a "geometry" thing than a "physics" thing. Simply put, when a cylinder head is shaved (or a cylinder block is "decked"), it is measured in thousandths of an inch (or millimeter, if you're living in the metric world). Now, this may not seem like much, only talking about paper thickness. HOWEVER, the shorter distance between the drive (crank) toothed belt pulley and driven (camshaft) toothed belt pulley center lines has changed enough that the timing belt tensioner will pull the belt in tighter. This changes the angle of the cam pulley in relation to the crank pulley at top dead center...i.e. the crank is "straight up" and the cam is off by a couple of degrees.
This is why hi-po overhead cam engines frequently use the adjustable cam pulleys, because the head shaving increases compression which is good for performance, and then you can adjust the camshaft back to correct top dead center alignment, or some guys I believe actually advance the cam timing a bit.
Hope I haven't confused you, it kinda confuses me, actually!
Regards,
Shea
| By -Andrew Smit- (Cvcc_Wagon) (209.121.214.102) on Friday, July 02, 2004 - 08:04 pm: |
i have been reading all over that when you shave the head down it changes the timing, i was just wondering what the physics behind this is. it doesn't seem logical to me that simply moving the two belt pulleys closer together would change anything. or does it have to do with where the teeth on the belt fit on the pulleys?
