| By luckyluciano2 (68.104.196.30) on Saturday, July 24, 2004 - 01:38 pm: |
turns out you were right don i did have 1300 flywheel i forgot i had that one machined with the 1300 crank i had. 1300 clutch fit right in.Thanks
| By Butch Dennis (216.40.234.136) on Tuesday, July 20, 2004 - 10:38 pm: |
On the clutch / flywheel situation, it turns out the 2nd generation flywheels have about a .200 in. shallower step than the 1st generation series. I ran into this while trying to put a lightened 1200 flywheel into a '82 civic wagon w/1500. Just keep the flywheel/pressure plate/ transmissions together and you will not have any problems.
| By luckyluciano2 (68.104.196.30) on Monday, July 12, 2004 - 12:37 am: |
thanks guys. i cant wait to drive her again its been two years the my civic has been off the road
| By Glenn Biscan (211.30.144.154) on Sunday, July 11, 2004 - 01:40 pm: |
i made my own gaskets for the canon manifold. Just went to the local parts supply got a 10m roll of gasket paper and now i make all my own gaskets and is heaps cheaper
| By Don (199.2.139.216) on Sunday, July 11, 2004 - 07:09 am: |
Nope get a 1980 1300 pressure plate
| By luckyluciano2 (68.104.196.30) on Sunday, July 11, 2004 - 02:31 am: |
thanks don! oh so do you think i could just machine out the middle a bit to make it work?
| By Don (199.2.139.202) on Saturday, July 10, 2004 - 10:53 pm: |
Oh TWM "the weber man" or pierce manifolds has gaskets.
| By Don (199.2.139.202) on Saturday, July 10, 2004 - 10:51 pm: |
I had the same problem... I think you have a 1200 pressure plate and a 1300 flywheel.
| By luckyluciano2 (68.104.196.30) on Saturday, July 10, 2004 - 07:07 pm: |
two questions: im putting my engine in and i have purchased to differnt clutch kits and when i set them in the flywheel they barely make it over the dowel pins and there is like 3/8" of space between the pressure plate and flywheel. i tried the clutch in the 1500 flywheel i had, to see if they gave me the wrong clutch and it was better but still wrong. any suggestion? can i machine out the center and not the rim where the screws tread into?
#2 what gaskets do i use for cannon single side draft manifold between the carb and manifold. with 40doce and where do i get em?
