| By Jonathan (68.193.10.141) on Friday, July 23, 2004 - 08:03 am: |
You might be able to find out what it's for at a Honda dealer. The slhondaparts.com web site has a place to put in the part number, but all it comes back as is "gasket set, A". It doesn't return the specific application.
| By 79EK1 (63.195.80.15) on Friday, July 23, 2004 - 07:55 am: |
The only way I know to verify the kit is for a 75 Civic, is to go to the following site and look up the gasket kit and see if the part number matches. Unfortunately, I haven't found a way to look up Honda part numbers directly. Hope that helps. Dan
http://www.slhondaparts.com
| By Canada76civic (Canada76civic) (68.146.162.237) on Friday, July 23, 2004 - 07:04 am: |
No one knows what engine size this gasket kit is used for? I'm told by the seller that it is for a 1975 Honda Civic.
| By Canada76civic (Canada76civic) (68.146.162.237) on Thursday, July 22, 2004 - 06:52 am: |
Hi, ok I need to know what type of engine does the gasket kit go on? I found one that looks like it should fit a 1200 engine, but not sure...?
Here's the original kit number - #06110-634-671.
The kit is NOS Honda parts. Thanks for any help!
