| By Butch Dennis (216.40.234.244) on Friday, August 06, 2004 - 01:14 am: |
This may be the same way as Bruce describes it, but I believe it's easier to remember.
With #1 cylinder on TDC, adjust the intake, exhaust, and aux. on number 1 cyl, the intake and aux. on number 2, then the exhaust on number 3.
Turn the engine until #4 cyl. is at TDC (watch for rotor in the dist. to point to #4, close enough is enough) then adjust number 4 intake, exhaust, and aux., number 3 intake and aux., and number 2 exhaust.
This will work with any engine that has the firing order 1-3-4-2. Now you just have to figure out which valve is which.
| By sdcvcc (68.101.197.93) on Thursday, August 05, 2004 - 10:06 pm: |
Your awesome Bruce. I will try that this weekend. IF that dont fix the problem then its off to the junkyard or to the rebuilders.
thanks man
| By bruce (4.159.179.2) on Thursday, August 05, 2004 - 11:12 am: |
ok..engine on TDC #1 cyl. adjust intake 1 and 2 cyl. ex. 1 and 3 cyl. aux. 1 and 2 cyl. rotate crank 360 (cam 180) so #4 cyl is TDC. adjust intake 3 and 4 cyl. ex. 2 and 4 cyl. aux 3 and 4.
strating from your cam - valves are I-E-E-I-I-E-E-I (EIEIO OLD MCD...)
| By Zippy (Zippy) (12.106.14.107) on Thursday, August 05, 2004 - 10:35 am: |
Do it in the order it says in the book. Yeah, if you truly understand the intricices of the way that the valves and cam work together and you want to do a lot of extra work then you could probably think of a harder way to do it than the book prescribes. But if that dosen't sound like what you want to do then follow the instructions. It's an easy job. Just a few things to watch out for: don't over torque the lock nut and don't make the gap too small. If the gap is too small you will toast your valves.
| By bruce (66.20.225.156) on Thursday, August 05, 2004 - 09:13 am: |
ok..sdcvcc.....your intakes are .006 including aux. valves. exhaust valves are .008. I will get the order when I get home.
| By sdcvcc (68.101.197.93) on Wednesday, August 04, 2004 - 09:48 pm: |
Hey Bruce. What order do I adjust the rockers in?
The book says, intake- exhaust, 2,5- 5,7.......
kinda confusing. I am assuming I can just turn each cylinder to TDC and then adjust each set.
And how important are my CVCC valves?
Joel
| By Bleedy (Bleedy) (24.68.6.16) on Wednesday, August 04, 2004 - 09:02 pm: |
Okay, cool. I set all the valves to .006, so it should be all good. I was thinking I might have screwed up her car.
My other theory on why it's clicking is dirty oil. When we pulled off the rocker cover, there was dirt everywhere. I say dirt because it's not a oily consistency at all. It's more like clumps of particles. I scraped as much as I could off the inside of the rocker cover, which was about 1/4" in some places. I also blasted it with degreaser. Wasn't totally clean when I put it back on, but good enough for now. I haven't had a chance to drop the oil pan, but I think I'll clean that out, replace the pump screen and maybe do some kind of oil system cleaner after that.
| By bruce (4.159.176.150) on Wednesday, August 04, 2004 - 05:15 pm: |
no bleedy I did... .004 to .006 for both is what my book said. I been working on cvcc's so long...
| By Bleedy (Bleedy) (24.68.6.16) on Tuesday, August 03, 2004 - 07:27 pm: |
.006 for intake and .008 for exhaust on an EB2? I think Haynes said it was .005-.007 for both. Am I reading the wrong thing in the specifications section?
| By sdcvcc (68.101.197.93) on Tuesday, August 03, 2004 - 06:14 pm: |
What else shall I buy to get the head redone?
And in the book it says to do the valves in a secific order. But it doesnt make sense. Can I just adjust each gap in any order?
thanks for the info
Joel
| By bruce (4.159.56.250) on Tuesday, August 03, 2004 - 06:05 am: |
.006 for intake. .008 for exhaust. slide feeler gauge in and tighten till you feel it dragging. I bought the valve seals and took it to a head shop down here, it cost me 112.00 to have the head re done. same guy did my block, 65.00 for my block.
| By sdcvcc (68.101.197.93) on Monday, August 02, 2004 - 08:53 pm: |
I need the same help. But I am not sure if I have an engine knock or if its just rockers.
I did the same adjustment trying to use the manual, but Haynes sucks. It says to adjust them in order using TDC piston 1. Then TDC piston 4. I just turned the crank until each piston was TDC then I adjusted the gap. Thinking about just rebuilding the whole head. Anyone know where I can get a head rebuild kit???
| By Bleedy (Bleedy) (24.68.6.16) on Monday, August 02, 2004 - 08:01 pm: |
Getting a 77' 1200 up and running. It's going pretty well so far. I set the valve clearances today, but I think it's clicking like mad. The correct clearance for the valves is .006", right? Both intake and exhaust?
How exactly do you all set the clearance? I loosened the nut, put in the feeler gauge, tightened the screw so I couldn't move it, backed it off so I could, then tightened the nut again. I also noticed that there is some play in the rockers. It's possible to push them up a little, increasing the gap. Am I supposed to do that?
Thanks for all your input. I have searched this board, and checked the manual several times. I don't think it's the fuel pump clicking either.
