| By H (68.148.227.142) on Tuesday, August 31, 2004 - 08:30 pm: |
Ooooppppssss.Pic 5 is not a cvcc intake its an EN exhaust mani.Pics 6 & 7 are switched.
| By H (68.148.227.142) on Tuesday, August 31, 2004 - 08:21 pm: |
79-81 EL head gasket
79-81 EL gasket
Used 79 EL gasket
79-81 EL header
?? cvcc intake
?? cvcc header
?? cvcc exhaust manifold
82-83 intake
82-83 intake
| By H (68.148.227.142) on Tuesday, August 31, 2004 - 06:33 pm: |
The 79-81 and 82-83 EL are all 4 port,only the valve sequence is different.(at least the ones I have/had are anyways).
Lazy if your engine is an EL it should be 4 port.
Sorry to contradict my previous post.
I belive the 79-81 EL 4 port head will bolt to the 76-78 EG block but not to the 82-83 EL.The exhaust manifolds will not interchange.
I will post some pics later to help clear this up.
| By lazy (165.228.57.19) on Friday, August 27, 2004 - 03:08 am: |
cool, thanks guys
looks like I have a 2 port
| By H (24.70.95.205) on Thursday, August 26, 2004 - 04:36 pm: |
If the timming case is black it is a 82-83 if it is beige it is a 79-81
| By -Andrew Smit- (Cvcc_Wagon) (154.20.215.113) on Thursday, August 26, 2004 - 11:28 am: |
look at the header, if it's a 2 port the runners will be way under the carb, if its the 4 port the outer two will be right on the outside
| By lazy (165.228.57.19) on Thursday, August 26, 2004 - 03:08 am: |
i want to figure out if my EL is a 2 or 4 port but don't want to pull the header off... is there any other way to tell if I have a 79-81 or 82-83?
| By H (68.148.227.142) on Wednesday, August 25, 2004 - 05:18 pm: |
A 78 1600 non cvcc would be an EG.The 79-81 EL head/intake/exhaust will fit.The 82-83 will not.Not all non cvcc haeds are 4 port.(only the 82-83)Your 78 cvcc exhaust mani will fit the 78 EG
| By -Andrew Smit- (Cvcc_Wagon) (24.86.60.160) on Wednesday, August 25, 2004 - 11:28 am: |
82/82 non cvcc heads are 4 port. 80/81 are 2 port. not sure about the 78 tho, what is the engine code of that motor. is it the same as the EL1 1602cc
| By Jonathan (68.193.6.173) on Wednesday, August 25, 2004 - 10:09 am: |
I thought that all Canadian non-CVCC heads were 4-port, but I could be wrong. There's a company (Impact parts, I think) that still had headers to fit Canadian heads a few months ago, they might still have some. You will need the intake and carb from the non-CVCC head.
Not sure on the later heads fitting the earlier blocks, though.
| By CVCC x 2 (67.71.178.201) on Wednesday, August 25, 2004 - 09:48 am: |
I have located an 8 valve non-CVCC head from a canadian 78 Accord 1600, but there is no exhaust manifold. Will the exhaust manifold from my 78 Civic CVCC fit and work the same?
Also, there is an 82 Accord 1600 non CVCC engine available, will that head fit on my CVCC block?
I would assume that the 82 Accord would be a 4 port head, where as the 78 Accord would be a 2 port??
Any help would be greatly appreciated!!
