| By 1300dx (24.251.49.100) on Thursday, September 16, 2004 - 07:39 pm: |
'82-'83 US Accords had cable clutches. I put a GJ trans on an '82 EK/EL motor by machining the flywheel to fit the crank. It was relatively cheap to machine the mating surface to fit and drill out the bolt holes bigger.
| By Jarcaf (Jarcaf) (207.55.238.216) on Thursday, September 16, 2004 - 03:22 pm: |
I've got an EK1 in my 82 sedan w/ a cable clutch here in the states. I have to look at what the year is on it, since it was a mix & match, but i have a feeling that it's an '80 5-spd tranny on an '81 block w/ a prelude head. I'll go down and look at the records a little later to make sure.
| By lazy (165.228.57.19) on Thursday, September 16, 2004 - 01:05 am: |
The later model accords came with cable clutch - at least here in Australia... perhaps you could look into whether or not the same holds true on your side of the globe.
| By 79cvcc (69.19.0.1) on Wednesday, September 15, 2004 - 11:32 pm: |
does anybody have any idea what i can do cause i really need to get this car on the road Thanks Jason
| By 79cvcc (198.81.26.70) on Monday, September 13, 2004 - 01:14 pm: |
Ok i have a 79 civic with an em-1 in it well i want to put an ek-1. how do i do the clutch. cause i cant use the one out of the accord because its hydralic. and the flywheel off of the em-1 wont bolt up to the ek-1. i have a problem please help thanks Jason
