| By lawrence P. (216.201.129.210) on Wednesday, June 15, 2005 - 09:50 am: |
I used the rear back plates and drums off of an '83 S model civic I had. They were both 181mm drums so a wasn't concerned with the over-all diam. The drums off the civic were a little narrow and bottomed out on the spindle. I just took a .032 machine shim I found at the local hardware store and slid it between the inner bearing and inner seal. Works great.
| By Anthony Stewart (203.173.8.223) on Tuesday, June 14, 2005 - 11:30 pm: |
HOW DID YOU DO THE REAR BY THE WAY?
| By Lawrence P. (216.201.129.210) on Tuesday, June 14, 2005 - 10:16 am: |
What about the spline pattern in the hub. I have an '81 accord that I have done the 4x100 rear drum conversion but am having trouble with the front. The Spline on the half-shaft is a 24 tooth and the spline on the hub I picked up from the salvage yard off an 81 civic is a 23 tooth spline. Any thoughts, I'm getting a little frustrated.
| By Anthony (202.147.83.113) on Saturday, October 09, 2004 - 09:35 pm: |
98 Accord or Prelude VTI-R or some CRV calipers, will bolt on. take your knuckle with EN1(1980) hub pressed in, to your wrecker and try bits out
| By Colza (Colza) (219.88.58.223) on Saturday, October 09, 2004 - 01:09 am: |
Do the 98 accord calipers bolt on? They must be HUGE :D
| By ANTHONY (203.173.8.223) on Monday, October 04, 2004 - 10:28 pm: |
PRESS IN EN1 HUB AT FRONT, YOU CAN BOLT ON 88 CRX CALIPERS, AND DISCS,OR GO BIGGGER WITH 98 ACCORD CALIPERS AND 90 INTEGRA DISCS, REARS IS 81 CIVIC WAGON DRUMS AND BACKING PLATES, BOLT ON, CHANGE THE HOLES THATS IT
| By sd1gencivic (68.101.197.93) on Monday, October 04, 2004 - 07:45 pm: |
I picked up an 81 Accord SE, and I was wondering if I can do the 4x100 swap with an 83 or newer hub with the wagon knuckles on this one.
Still doing it on my 75 Civic, but since I need new suspension on the front of this Accord I wanna do the bigger brake and hub swap.
thanks for all the help
