| By Glenn Biscan (211.30.144.154) on Wednesday, October 20, 2004 - 08:01 pm: |
i actually bought a kit so im not sure what other parts you might want 2 use on a different motor
best thing to do is to talk to your local turbo shop, they will help in getting some infomation on the turbos suitable for your motor
| By malcon pierce (Project79) (68.63.18.219) on Wednesday, October 20, 2004 - 05:49 pm: |
oh ok. i gotcha. what kind of turbo do you recomend? i have a t3 off of an eclipse. it has an intdrnal waste gate though. and what carb would be best for the pull through?
| By Glenn Biscan (211.30.144.154) on Wednesday, October 20, 2004 - 05:25 pm: |
not sure exactly were i will put it, but there is a mandrel bent piece of exhaust from the exhaust manifold ( still using standard manifold) and i will plug the wastegate into there where ever i can fit it along that pipe
also still have to make the dump pipe
| By malcon pierce (Project79) (68.63.18.219) on Wednesday, October 20, 2004 - 05:05 pm: |
yeah i know that about the blow off vauve. i just thought the external waste gate went between the carb and the turbo . i learned somthing knew, so where exactly will you put it?
| By Glenn Biscan (211.30.144.154) on Wednesday, October 20, 2004 - 04:21 pm: |
not sure of the offset on the wheels, as i bought them second hand off a member on this board, but they are 195 wide and 14 "
| By Glenn Biscan (211.30.144.154) on Wednesday, October 20, 2004 - 04:18 pm: |
the wastgate is the same as on a normal turbo car, but i am using an external wastgate, it will sit underneath the car with the screamer pipe aiming right @ the road
if you actually mean blow off valve, in a carby turbo you cant run a blow off valve as they normally sit between the turbo and the intake manifold, but because i have fuel going through there, i am unable to use 1 as fuel would go everywhere and a massive diaster could be had
| By malcon pierce (Project79) (68.63.18.219) on Wednesday, October 20, 2004 - 11:58 am: |
so thats the origional intake mani? how do you run the waste gate with a pull through? or is that for another car? i like the cars man. they look nice. im trying to get an ek1 moter and turbo that, but i still kinda want to build the 1200, since i already have it and all.
| By lazy (165.228.57.19) on Wednesday, October 20, 2004 - 07:12 am: |
niiice.. what wheel/tyre/offset combo is that?
| By Glenn Biscan (211.30.144.154) on Wednesday, October 20, 2004 - 06:56 am: |
I been working on my purple race car a fair bit
check it out
www.members.optusnet.com.au/biscan
