| By Zauster (198.53.172.32) on Monday, November 01, 2004 - 03:53 pm: |
I had the same problem - it's caused by a loose wire connection under the dash; right below, little left of the steering column. Not exactly sure which wire as I was annoyed with it and just reached down and wiggled the wires. Hasn't happened since - over 10,000kms ago.
David
78 1200
| By Chaffneue (Chaffneue) (66.183.190.188) on Monday, November 01, 2004 - 08:09 am: |
could be a broken timer or a rotted connector under the seat.. you can scotch bright the connector terminals. Not sure you fix the timer. my buzzer was burnt out so I just disconnected the light. i usually know when I've got my seatbelt on :D
| By Dallas_tom (4.131.65.66) on Monday, November 01, 2004 - 07:29 am: |
My Fasten Seat belt light and buzzer go on and off randomly all of a sudden. With the seat belt clicked in, the buzzer is quiet, but the light still comes on and off. Is this a loose wire? Where should I look?? Thanks!
Tom-
