| By evileb2 (219.88.63.120) on Sunday, November 07, 2004 - 08:59 pm: |
bugger! my email is jotary20b_@hotmail.com
| By evileb2 (219.88.63.120) on Sunday, November 07, 2004 - 08:57 pm: |
the pump im using i picked up from a race supply store in auckland -was better for the aplication as it runs low p.s.i between 2.5 to 6psi so is good for dellorttos -and the holley fuel pumps are expensive (about 200)and also would require a regulator (another 150-200) its mounted on a bracket under the airfilters was pretty cheap mod pump $80 + $25 new fuel filter + a metre fuel line $25 and has helped heaps as it was starving past 5k -the delortos are sweet to drive and they have a good nice sound but airflow is the big issue (im currently dealing with mine)and the fuel bill hasnt burnt a hole in my pocket-if you are interested in maybe getting one of these pumps email me could sort some thing out
and its the metric bugger! lol
| By Glenn Biscan (211.30.144.154) on Sunday, November 07, 2004 - 03:31 pm: |
yeah it workd in the past :D
i have another car with the booster that is for going around corners
| By jim_mac (211.31.11.116) on Sunday, November 07, 2004 - 03:26 pm: |
hey Glen
looking at your picture I hope that single master cyclinder is not what you rely on for stopping..
Jim
| By Kurt (205.250.75.226) on Sunday, November 07, 2004 - 11:52 am: |
I'm running a Carter pump on my Dellorto set up btw 2-4 psi and it works fine. I'm not running a regulator either so I guess I was lucky
The Dellortos like good volume but low pressure.
| By Zippy (Zippy) (68.85.166.249) on Sunday, November 07, 2004 - 08:38 am: |
Be sure you run a fuel pressure regulator and keep it in the 2-4 psi range. I don't know what the metric units are but the fuel pressure is really low. Big hose, low pressure. Otherwise the float stays open and you get all sorts of fuel metering issues.
| By Zippy (Zippy) (68.85.166.249) on Sunday, November 07, 2004 - 08:35 am: |
On my 1200 eb3 I have 5 cm between the end of my trumpets and the fire wall. My trumpets are about 3.5 cm long. The stock fuel pump is definately inadequate. I run headers, a hot cam, lightly worked head/intake, and the Dell 35s on a stock shortblock up to about 7k rpm. With the stock pump I was having fuel starvation issues above about 5k rpm.
| By Glenn Biscan (211.30.144.154) on Saturday, November 06, 2004 - 10:34 pm: |
had sooo many problems with fuel delivery in the past, that i would of prefered to stay with the mechanical, but if it doesnt flow enough ill have to put the electric setup that i used with the single 45mm webber
fuel pump goes from the tank into a surge tank, and then another pump that comes out of the surge tank and into the carbies, with a fuel pressure reg near the carb
| By jim_mac (211.31.11.116) on Saturday, November 06, 2004 - 12:06 am: |
evileb2
I'd like some info on the electric pump. Whats the driving like with twin dellortos? Are you set up for race only or just street driving?
I am just about to fit dellortos 35's. Any other thing I need to know?
Jim
| By Hugh Johnson (Oneson1) (144.138.198.131) on Thursday, November 04, 2004 - 10:58 pm: |
Is that the metric buuger or an imperial buuger?? Being from OZ I tend to work in metric and like you I want to know! So, measure up fella!!-how many buugers are there, there! buuger all or buuger none! (thats the problem with buugers as a measure, it's either all or nothing)
hugh
| By evileb2 (203.96.100.13) on Thursday, November 04, 2004 - 01:04 pm: |
what is the actual space mm wise between trumpets and firewall? photo makes it look like buuger all
| By Don (199.2.139.241) on Thursday, November 04, 2004 - 05:29 am: |
The dell manifold allways has fit
its the bigger Dual Webber Dcoe manifold that has the problem.
| By evileb2 (219.88.59.212) on Thursday, November 04, 2004 - 04:34 am: |
hey bro im running a set of dellorotto 35's they fit...just. im using redline airfilters cause they are the soft sponge type. but one point you need to remember is that the stock fuel pump wont flow hard enough i had to up-grade to a electric one it cost me about $80 nz and hi flow filter $20 works mint. ill find out the brand of it if you want?
| By Glenn Biscan (211.30.144.154) on Thursday, November 04, 2004 - 12:14 am: |
hey everyone
had some trouble with my turbo motor ( put it in the car and motor is unable to b turned over @ the crank)
was just testing out the set of twin dellortos, to see if they fit between the stock fuel pump and the dizzy check it out for your self
