| By Kurt (205.250.75.226) on Friday, January 28, 2005 - 08:47 pm: |
My Weber had a 'spout' for a return line back to the tank. When I first got the car running I accidentlly put the fuel line to it and could not figure out why the car kept stalling.
| By bruce (4.159.182.239) on Friday, January 28, 2005 - 06:25 am: |
I ditched my canister when I put the weber on, I did not do anything with the line, it is just there, does not seem to leak any gas of fumes.
| By malcon pierce (Project79) (68.63.17.76) on Thursday, January 27, 2005 - 10:39 pm: |
what did you do with your second line?
| By malcon pierce (Project79) (68.63.17.76) on Thursday, January 27, 2005 - 06:39 pm: |
ok iff i loose the carb canester thing. do i nee thanksd that second fuel line? if so what do i hook it up too?
| By malcon pierce (Project79) (68.63.17.76) on Thursday, January 27, 2005 - 05:54 pm: |
i have an electric fuel pump i am going to install. but it says it should be hooked up to the oil pump safty switch. or the ignition volt safty switch..anyway has anybody else installed one and what did you hook it up to?
| By malcon pierce (Project79) (68.63.17.76) on Thursday, January 27, 2005 - 11:05 am: |
awesome. shoot man. i think ill take it off too.. im going to start reasembly on the engine today and then body work! yay.
| By Darrell--Arizona-- (68.109.151.121) on Thursday, January 27, 2005 - 06:34 am: |
Just curious... When I had my engine my car always smelled of gas, but I could never find any leaks or broken hoses. I wonder if my canister was all used up. Hmmm
| By Kurt (205.250.75.226) on Wednesday, January 26, 2005 - 10:11 pm: |
The black box is a charcoal canister for emmissions. I ditched mine. Just be careful as I seem to recall that the return line to the tank goes through there. Fumes = fire
| By malcon pierce (Project79) (68.63.13.244) on Wednesday, January 26, 2005 - 09:36 pm: |
what is the black tank looking thing that says carb tank or somthing on top. the black thing that mounts behind the carb on ther fire wall? and do i need that vacume hose hokup thing that gos on the fire wall? it all seems sort of pointless. i just want to take off everything that is not nessesary... on another note.
