| By 79guy (79guy) (206.148.40.40) on Tuesday, February 15, 2005 - 01:20 pm: |
So the bolt pattern on a civic 1200 is 4x120... Does anyone know the factory offset?
| By Jason (Roadwarrior) (24.80.29.179) on Sunday, February 06, 2005 - 01:51 am: |
You will have to check with the local motor vehicle laws in your area regarding modifying wheels. It may be illegal.
| By Jason (Jason) (205.188.116.199) on Sunday, February 06, 2005 - 12:12 am: |
Thanks for the info. One more question on the issue. If the bolt pattern is 4x114.5 can the holes be extended to the 4x120 or is there more to it?
| By John S. (65.70.157.90) on Friday, February 04, 2005 - 07:42 pm: |
That would make a lot more sense than to risk ruining a set of those wheels.
| By sdcvcc (68.101.197.93) on Friday, February 04, 2005 - 06:22 pm: |
I know my 78 Corolla is 4x114.5. Not sure if when that started. Anything can be drilled really, but then there is the question of strength loss from doing it. What about the 4x100 conversion using newer hubs?
| By Jason (Jason) (205.188.116.199) on Friday, February 04, 2005 - 01:06 am: |
Hello everyone, I met a man that has a set of panasport look-a-likes on an older toyota corolla and the bolt pattern looks close. He said they might fit anyone have any info on this. He also has a set of 4x100 I believe can these be redrilled to fit 4x120?
