| By Kurt (205.250.75.226) on Tuesday, February 15, 2005 - 09:50 pm: |
great, thanks Adrian.
| By Adrian (Evocivic) (203.42.97.141) on Tuesday, February 15, 2005 - 07:42 pm: |
94305-80202
It's just an 8x20 roll pin (or might be called a spring pin) so if honda doesn't have one it shouldn't be hard to get one from a good nut and bolt shop.
Just a standard pin punch. Buy yourself a set of them from any good tool shop ... you won't regret it! I think I spent around $10-15 on a set some years ago and don't know how I ever did without them.
| By Kurt (205.250.75.226) on Tuesday, February 15, 2005 - 07:33 pm: |
Yes I have been there. Anyone know the part number for the pin?
Also, is the pin punch a Honda tool? I assume its like a tool to remove links from a m/c chain?
| By Adrian (Evocivic) (203.42.97.141) on Monday, February 14, 2005 - 09:36 pm: |
Around 90% of the sideways play is caused by the little roll-pin that connects the shift linkage to the gearbox being worn. They cost a dollar or so from Honda and take a couple of minutes to change. Use the correct tool (a pin punch) when knocking the old one out or it'll take ages plus lots of swearing and possibly missing skin.
| By Kurt (205.250.75.226) on Monday, February 14, 2005 - 09:24 pm: |
can you still buy the assembly. I am making the short shifter but it won't get rid of the play I have side to side
| By bruce (4.159.56.88) on Monday, February 14, 2005 - 03:57 am: |
get a new shifter mount, honda still has them for around 25 bucks, I had the same thing happen. I bought 2 while I was at it.
| By Jason (Roadwarrior) (24.69.255.203) on Monday, February 14, 2005 - 02:25 am: |
Ok, so the shifter mount finally gave up, and the shifter fell through the floor. Anyone have any brilliant ideas how to repair this?
I think the original rubber cracked due to the engine/tranny movement.
Suggestions?
