| By Glenn Biscan (211.30.144.154) on Tuesday, March 01, 2005 - 02:48 am: |
thanks adrian
i got the starter motor working
but it isnt meshing with the flywheel
i just used the standard EC flywheel but that should of been fine right ?
| By Adrian (Evocivic) (203.42.97.141) on Monday, February 28, 2005 - 11:07 pm: |
One is the main power wire (big fat one), one is the starter wire (operates the solenoid) and one is the ignition ballast resistor bypass wire (bypasses the ballast resistor when starting).
The City Turbo wouldn't need the resistor bypass wire so that will be the one that is missing.
Why don't you just use the original starter?
| By Glenn Biscan (211.30.144.154) on Monday, February 28, 2005 - 10:26 pm: |
Just changed over the auto box in the wagon to a honda city turbo box
the old gearbox had 3 wires for the starter motor , the city turbo starter only has 2.
why is this ???
and where do they go now ?
