| By Jdupre (Jdupre) (24.5.152.32) on Saturday, March 12, 2005 - 01:36 pm: |
When I replaced my ED engine with an EF I had the same problem. The flywheel on the EF was binding with the original bell housing. The flywheel is the same diameter, but I think it was a bit thicker or something(?) I cut a round piece of cardboard to match the flywheel, and used that as a guide for grinding. It didn't take much.
- Joe
| By Glenn Biscan (211.30.144.154) on Thursday, March 03, 2005 - 04:14 am: |
tryed making spacers it worked but starter motor didnt reach
so i put the GN gearbox in
it was absolutely no hasles would recomend that any1 who wants to change just put that box in from the start
| By Glenn Biscan (211.30.144.154) on Thursday, March 03, 2005 - 12:07 am: |
dad said he did change the flywheel to the manual 1
but put the striped bolts bak in :S
ill pull it out now and see wots going on
thanks again
| By H (24.70.95.204) on Wednesday, March 02, 2005 - 06:36 pm: |
Maybe this will help.
http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&catcgry1=Civic&catcgry2=1978&catcgry3=WGN+**&catcgry4=KHHMT&catcgry5=HMT+++++TORQUE+CONVERTER
http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&catcgry1=Civic&catcgry2=1978&catcgry3=WGN+**&catcgry4=KA5MT&catcgry5=MT++++++CLUTCH
| By H (24.70.95.204) on Wednesday, March 02, 2005 - 06:23 pm: |
If your changing from auto to manual then the old auto flywheel has got to go.Auto and manual flywheels are totally different.
| By Colza (Colza) (210.54.193.173) on Wednesday, March 02, 2005 - 03:33 pm: |
Vice grips mate. Big ones =D
| By Glenn Biscan (211.30.144.154) on Wednesday, March 02, 2005 - 01:28 pm: |
ok justin
but if i use the EC flywheel ( some1 has had a go it this b4 and all of the bolts are stripped on the flywheel ) and a GN civic gearbox will that work ok without having to modify things ?? as i cant get the flywheel off
cheers thanks for your help
| By Justin (24.85.53.81) on Wednesday, March 02, 2005 - 09:03 am: |
you probably have to space over the bottom tranny mount(or machine the back of the flywheel to clear the mount), I've run into this problem a few times
| By bruce (4.159.56.68) on Wednesday, March 02, 2005 - 03:55 am: |
it is probably the flywheel jamming someplace.
| By Glenn Biscan (211.30.144.154) on Wednesday, March 02, 2005 - 02:32 am: |
gee wiz sorry bout the spelling
I pulled the auto out and replaced it with a city turbo box
( put that on 2nd line hehehe )
| By Glenn Biscan (211.30.144.154) on Wednesday, March 02, 2005 - 02:24 am: |
Hey all
i ripped auto the semi auto in the wago and put in a honda city turbo gearbox/starter motor
after much effort i got the starter motor to work only to find out that something is not working right
i cant turn the engine over ( feels seized )
there is a clutch pedal
tried to turn it over while foot on clutch
cv's arent in yet
using EC flywheel
wot could the prob be ?
