| By Jarcaf (Jarcaf) (207.55.238.216) on Monday, March 28, 2005 - 07:23 pm: |
Anyone interested in turbocharging should check out that article. Very inspiring
Also, I found an article about the Formula SAE program at some colleges. I'm going to Oregon State next fall and they participate in it, so I'll be joining up next fall. Pretty cool little cars...check it out at http://www.fsae.com/
and at http://groups.engr.oregonstate.edu/SAE/Formula/
| By Jarcaf (Jarcaf) (207.55.238.216) on Thursday, March 10, 2005 - 07:29 am: |
awesome. thanks a lot!
| By John S. (66.142.233.52) on Thursday, March 10, 2005 - 01:16 am: |
This months Grassroots Motorsports Magazine has an excellant article on turboing cars, as well as info on which of the available factory pieces are recommended yea or nay, and why.
| By DaRk (66.50.182.207) on Wednesday, March 09, 2005 - 08:39 pm: |
Well Guys I went to see it, and the body is SHOT...no good, only the glass' is good, of all sides...it does have 2 original rims...it has passenger door handle and trunk key latch? No emblems...it has grille and normal guages...I haven't checked under hood cuz' the passenger door was on top of hood so...hood was shut. I'll check that out during the week.To see what else I could get out. It also has the taillights. It's NOT CvCC ....
| By DaRk (66.50.13.38) on Tuesday, March 08, 2005 - 08:49 pm: |
I would like my daily driver to be running like that :D although tomorrow I'll be looking at an 88 CRX so I'll be checking that engine...
and tranny. Also my cuz'n told me that he saw a 1st gen CvCC somewhere near his house so I'm gonna check that out too...if there is any spare parts or somewhat I'll keep You guys informed
| By Jarcaf (Jarcaf) (207.55.238.216) on Tuesday, March 08, 2005 - 08:17 pm: |
I wonder what kind of horsies would come out of an EK w/ that kind of boost!? I don't ever plan on going THAT high, as a daily driver, but I'll want to turn up the boost eventually to at least around 12psi. I'll get the ARP rod bolts eventually, as I heard that those are generally the first things to go. Was it you that said that, or if not do you agree?
| By DaRk (66.50.13.38) on Tuesday, March 08, 2005 - 07:34 pm: |
14.5 1/4 :P neat...what other mod's did you have?
| By Glenn Biscan (203.166.96.240) on Tuesday, March 08, 2005 - 06:44 pm: |
was running about 26psi but the turbo fins were almost completely worn, and had alot of shaft play.
| By Jarcaf (Jarcaf) (207.55.238.216) on Tuesday, March 08, 2005 - 06:09 pm: |
What kind of boost psi are you running, Glenn?
| By Glenn Biscan (203.166.96.238) on Tuesday, March 08, 2005 - 06:07 pm: |
the rhb5 turbo i had on the civic was totaly worn out and still had good throttle response and good top end, and yeilded a 14.5 1/4
| By DaRk (66.50.13.38) on Tuesday, March 08, 2005 - 05:33 pm: |
Yea...I've seen the 323's and they DO move good
| By Jacob (65.113.241.30) on Tuesday, March 08, 2005 - 02:58 pm: |
I've done a fair amount of research on this subject. What I've found is that the T2 from the Sunfire is a good sized turbo (have one on my shelf), as is the RHB5 VJ11 from a Ford Probe, and the RHB5 VJ14 from the 323GTX. Either of these turbo's should flow plenty of air for the 1.2L and retain good response. Plus, the RHB5's are a dime-a-dozen on ebay.
| By DaRk (66.50.182.21) on Monday, March 07, 2005 - 06:04 am: |
Ok thanks Jarcaf and Glenn...
| By Glenn Biscan (211.30.144.154) on Monday, March 07, 2005 - 02:14 am: |
The rayjay kit has a surprisingly large turbo. It’s near 2.5 times the size of the ihi rhb5 turbo I was running on the city turbo motor (same displacement)
But if @ all possible get a roller bearing model. They are superior to the rayjay, if you talk with your local turbo repair shop ( mine is the Garrett factory ) they will help you select a turbo that is correct for your motor, and this will yield better results for you.
| By Jarcaf (Jarcaf) (207.55.238.216) on Sunday, March 06, 2005 - 10:08 pm: |
Uh... well there really is no such thing as a turbo kit for 1st or 2nd gens anymore. That list is just for the turbos off of other cars. You're gonna have to make an exhaust manifold or flange adapter(like glenn said), and bolt a turbo on to that plus pipe it all up. As for which TURBO would be best from that list, the lower displacement engines are better; ie: the pontiac 1.8 and 2.0L w/ the garrett t2's.
I'm very new into this turbo scene, so guys like glenn, shnitzel, and colza are more qualified for these questions
Hope this helps though...
| By DaRk (66.50.181.43) on Sunday, March 06, 2005 - 09:43 pm: |
Jarcaf...will any of those fit my '79 1200 engine? and around what is the price range for the whole kit? Y'know like Everything... :D
| By Jarcaf (Jarcaf) (207.55.238.216) on Sunday, March 06, 2005 - 09:17 pm: |
Is there any particular reason you need a rayjay? garrett/airesearch t25's and mitsu te04h's are good sizes too. I yanked this list of stock turbo's from here: http://www.turbomustangs.com/forums/showthread.php?s=c585403874e81d294a0ef4396971f4aa&threadid=4365
BUICK GNX 87 3.8L GAR TB0348
BUICK Monte Carlo/Regal 78-83 3.8L carbed GAR TB0348
BUICK Riviera 80-85 3.8L GAR TB0308
BUICK Grand National/T-Type 86-87 3.8L (Intercooled) GAR TB0348 (TA48)
BUICK Trans Am 89 3.8L GAR TB0348 (water)
BUICK Century 78 3.8L GAR TB0301
BUICK Century 79 3.8L GAR TB0304
BUICK Century 80 3.8L GAR TB0308
GMC Syclone/Typhoon 4.3L Mitsu TDO6 17C/10cm2
CHRYSLER Conquest, Intercooled 87 2.6L MHI TD05
CHRYSLER Laser (Auto) 90-94 2.2L MHI TD04 13g
CHRYSLER Laser (Manual) 90-94 2.2L MHI TD05H 14b
CHRYSLER LeBaron 89-92 2.5L MHI TE04H
CHRYSLER LeBaron 88 2.5L MHI TE04H
CHRYSLER New Yorker 88 2.5L MHI TE04H
CHRYSLER New Yorker 84-87 2.2L GAR TB0335
CHRYSLER Town & Country 88 2.2L MHI TE04H
CHRYSLER Town & Country 84-87 2.2L GAR TB0335
CHRYSLER Charger/Shelby 87-90 2.2L GAR TB03 (water)
CHRYSLER Shelby CSX-Daytona/Baron GTC/Shadow ES 89-90 2.2L GAR TB03 VNT (variable nozzle)
DODGE 600 88 2.5L MHI TE04H
DODGE 600 85-87 2.2L GAR TB0335
DODGE Aries 88 2.2L MHI TE04H
DODGE Caravan 89-90 2.5L MHI TE04H
DODGE Conquest (Intercooled) 87 2.6L MHI TD05
DODGE Daytona 89-92 2.5L MHI TE04H
DODGE Daytona Shelby 88 2.2L MHI TE04H
DODGE Daytona Shelby 84-87 2.2L GAR TB0335
DODGE Lancer 89 2.5L MHI TE04H
DODGE Lancer 88 2.5L MHI TE04H
DODGE Lancer 85-87 2.2L GAR TB0335
DODGE Omni 85-87 2.2L GAR TB0335
DODGE Shadow 89-92 2.5L MHI TE04H
DODGE Shadow 88 2.5L MHI TE04H
DODGE Shadow 87 2.2L GAR TB0335
DODGE Spirit 89-92 2.5L MHI TE04H
EAGLE Talon (Manual) 90-94 2.0L MHI TD05H 14b
EAGLE Talon (Auto) 90-95 2.0L MHI TD04 13g
EAGLE Talon (Manual) 95-98 2.0L MHI T25 (45 trim)
FORD Mustang GT 85-86 2.3L GAR TB0344
FORD Mustang GT/T-bird 83-84 GAR (AiR) TB0344
FORD Probe GT 88-92 2.2L IHI RHB52W
FORD T-Bird 85-86 2.3L (auto) GAR (AiR) TB0344 (45 trim oil only)
FORD T-Bird 85-86 2.3L (Manual) GAR (AiR) TB03 60 trim (watercooled)
FORD T-Bird 87-88 (water) IHI RHB52
FORD Fiesta 90+ 1.6L GAR T2
FORD Escort 84-86 IHI RHB5
MAZDA 626, MX6 88-92 2.2L IHI RHB52W
MAZDA 323 GTX turbo 88-89 1.6L IHI RHB52W (water)
MERCEDES 300D, SDT, TD 78-84 3.0L GAR TA0301
MERCEDES 300SDL 78-83 3.0L GAR TA0301
MERCEDES 300SDL (Calif.) 86-87 3.0L GAR TB0359
MERCURY Capri 85-86 2.3L GAR TB0344
MERCURY Cougar 85-86 2.3L GAR TB0344
MERKUR XR4Ti 85-88 2.3L GAR TB0344
MITSUBISHI Eclipse (Auto) 90-94 2.2L MHI TD04 13g
MITSUBISHI Eclipse (Manual) 90-94 2.2L MHI TD05H 14b
MITSUBISHI Eclipse (Manual) 95-98 2.0L MHI T25 (45 trim)
MITSUBISHI Galant (Manual) 88-94 2.2L MHI TD05H
MITSUBISHI Starion (Intercooled) 85-87 2.6L MHI TD05
PLYMOUTH Acclaim 89-92 2.5L MHI TE04H
PLYMOUTH Caravelle 88 2.5L MHI TE04H
PLYMOUTH Caravelle 85-87 2.2L GAR TB0335
PLYMOUTH Conquest, Intercooled 85-89 2.6L MHI TD05
PLYMOUTH Laser (Auto) 89-94 2.0L MHI TD04
PLYMOUTH Laser (Manual) 89-94 2.0L MHI TD05H
PLYMOUTH Sundance 89-92 2.5L MHI TE04H
PLYMOUTH Sundance 88 2.5L MHI TE04H
PLYMOUTH Sundance 87 2.2L GAR TB0335
PLYMOUTH Voyager 89-90 2.5L MHI TE04H
PONTIAC Sunbird GT 88-90 2.0L GAR T2
PONTIAC Sunbird GT 84-86 1.8L GAR T2
PONTIAC Grand Prix 89-90 3.1L GAR T25 (water)
SAAB 9000 (16V Intercooled) 87-88 2.0L GAR TB0356
SAAB 900 (16V Intercooled) 87 2.0L GAR TB0339 (Oilcld)
SAAB 900 (16V Intercooled) 84-86 2.0L GAR TB0339 (Oilcld)
SAAB 9000 (16V Intercooled) 85-86 2.0L GAR TB0343
SAAB 900 (8V, APC) 82-84 2.0L GAR TB0321
VOLVO 200 82-84 2.3L GAR TB0313
VOLVO 740 89-93 2.3L MIT TD04H
VOLVO 740 87-89 2.3L MIT TD05
VOLVO 760 89-93 2.3L MIT TD04H
VOLVO 760 87-89 2.3L MIT TD05
VOLVO 780 85-87 2.3L GAR TB0363
VOLVO 780 90 2.3L MIT TD04H
VOLVO 780 87-89 2.3L MIT TD05
VOLVO 940 91-93 2.3L MIT TD04H
VOLVO 200 Watercooled Upgrade 82-84 2.3L GAR TB0368
VOLVO 740 (Oil Cooled) 83-85 2.3L GAR TB0326
VOLVO 740 (Watercooled) 85-87 2.3L GAR TB0363
VOLVO 760 (Oil Cooled) 83-86 2.3L GAR TB0326
VOLVO 760 (Watercooled) 85-87 2.3L GAR TB0363
VW Passat, 97+ (oil) 1.8L GAR GT15
GAR=Garrett=AiResearch, MHI=Mitsubishi Heavy industries, MIT=Mitsubishi
Sorry this takes up so much space, but I figure it's a good resource for us turbo-seekers...
| By Don (63.135.203.211) on Sunday, March 06, 2005 - 10:48 am: |
I think ramon still might have a few new?
| By DaRk (66.50.181.111) on Sunday, March 06, 2005 - 04:15 am: |
I'm pretty good at welding
so... But it's pretty difficult to find a rayjay turbo these days...
| By Glenn Biscan (211.30.144.154) on Sunday, March 06, 2005 - 01:32 am: |
you can put any turbo you want
are you any good @ welding ? if you are most of the hard work is making up exhaust manifold's or adapters to make the turbo fit
i have heard King motorsports made a kit but never seen one b4.
The rayjay kit is pretty good
| By DaRk (66.50.182.252) on Saturday, March 05, 2005 - 09:30 pm: |
instead of that rayjay turbo...
| By DaRk (66.50.182.252) on Saturday, March 05, 2005 - 09:29 pm: |
What other turbo systems could one install and the 1200 civics? and what mod. do we need to do ?
