| By bruce (68.156.75.5) on Monday, March 14, 2005 - 05:13 am: |
ok it cost me $25, you could go thru majestic honda and order one, I could ship you mine, if the old collar does not come off easy, which they don't, I have done 2 of these already, you will have to carefully cut it off, the best way I found is a cutting disc and make a diagonal cut from the top to bottom, so you just go thru the collar, then take a small cold chisel and pop it off. that way your using your own shifter, just replacing the boot. you can email me.
| By Glenn Biscan (211.30.144.154) on Sunday, March 13, 2005 - 10:19 pm: |
yeah thats the part bruce
how much $$$ you looking for the part ?
i think its going to be cheaper to buy sum1's old wreck and get the shifter out because noltec said 1month and they wouldnt quote me
| By bruce (4.159.56.118) on Thursday, March 10, 2005 - 06:02 am: |
is this the part your looking for???
if so I think you can still get them thru majestic honda here, I bought 2 of them a while back so I would have an extra one
| By Anthony (202.147.86.113) on Thursday, March 10, 2005 - 02:56 am: |
Funny, I spoke to Nolathane 2 weeks ago, they want $200AUs per coner/strut, to re-build them in Nolathane, with Spherical bearing, but you get to offset for negative camber, caster if you want.I thought $800AUS for the four was a little rude.
| By John S. (66.143.44.124) on Thursday, March 10, 2005 - 01:34 am: |
Adrian, do you know, or have you seen any specs on how well the urethane bonds to the metal pieces, as compared to the origional method of vulcanizing the rubber and metal together? I am still wondering if it might be possible to rebuild the front strutcaps using the origional inner and outer metal pieces but replaceing the worn out rubber with urethane.
| By Adrian (Evocivic) (203.42.97.141) on Wednesday, March 09, 2005 - 05:43 pm: |
I've never had one done there.
Just take the old one in and they'll melt out the rubber and pour new stuff in.
| By Glenn Biscan (211.30.144.154) on Wednesday, March 09, 2005 - 05:34 pm: |
yeah i have already contacted them and they dont remember doing adrian's
but they said that they should be able to
im just sending them a diagram of what i need done to see if they can do it some time soon
| By Anthony Stewart (203.173.8.223) on Wednesday, March 09, 2005 - 05:27 pm: |
THEY DID MINE 4 YEARS AGO, MAY HAVE IT ON FILE, BUT I DOUBT IT
| By Glenn Biscan (211.30.144.154) on Wednesday, March 09, 2005 - 05:23 pm: |
cheers thanks mate
| By Adrian (Evocivic) (203.42.97.141) on Wednesday, March 09, 2005 - 05:22 pm: |
Take your old one to Noltec and they'll rebuild it (replace the rubber with urethane).
| By Glenn Biscan (211.30.144.154) on Wednesday, March 09, 2005 - 05:02 pm: |
Hi everyone
the gearshifter on my civic fell through the floor this morning
Honda Australia no longer sells the rubber bar retainer any longer, so is there anyone in sydney who wants 2 sell a complete gear shift mechanism??
cheers thanks for your help
