| By sdcvcc (68.111.234.166) on Saturday, March 12, 2005 - 04:43 pm: |
ah. very true. I messed with the timing a little and now it is running but choking somewhat. Just need to tinker.
thanks fellas.
| By Darrell--Arizona-- (68.109.151.121) on Saturday, March 12, 2005 - 03:47 pm: |
The pump might have a pressure cutoff switch. So if there's enough pressure, the pump will stop.
Anybody know?
| By DaRk (66.50.181.216) on Saturday, March 12, 2005 - 01:46 pm: |
jejeje
| By sdcvcc (68.111.234.166) on Saturday, March 12, 2005 - 01:04 pm: |
looks like a steady flow, but not a strong flow. the funny thing is the I cant actually hear the pump working, until I take off the fuel line,. then I hear it clicking. went to the junkyard, gonna try this other pump.
And these damn Keihin's.
| By DaRk (66.50.181.216) on Saturday, March 12, 2005 - 11:13 am: |
How does the fuel come out, little by little or normal? Cuz mine was like that, the only thing that happened was that the diaphragm was already "worn out" and it was leaking through two little holes under it. I bought a new one and prob. solved.
But now my carb is messing around. Sort of like the same prob. You have. It starts but when I put it in gear and press the gas it sort of doesn't have power...
| By sdcvcc (68.111.234.166) on Friday, March 11, 2005 - 05:50 pm: |
car starts but runs barely. when I pull the fuel line off of the carb. the fuel comes out, and I hear the pump start to run. Otherwise I cant hear the pump running. Should I just test my fuel pressure? maybe jet clogged.
