| By nathan (24.85.232.159) on Thursday, June 23, 2005 - 09:39 am: |
Thats good to know...I am sourceing a re-built dizzy now...but I'll check into that.
-Thanks
| By thebige73@yahoo.com (Ejl2002) (66.84.137.106) on Wednesday, June 22, 2005 - 01:32 pm: |
No, no coil yet. I got my kit off of ebay, 58.00 plus shipping, pretty good deal. I am going to wait for my coil to go first, I have lots and lots of body work to do first. I also put in a reman distributor at the same time, the bushings were toast on my original, so make sure you check that out also. They are available for I think 65.00 for remans. Hope the info helps.
| By nathan (24.85.232.159) on Wednesday, June 22, 2005 - 12:55 pm: |
did you do there nice chrome coil to?
Because I'm planning on the pertronix kit for the dizzy (which sounds like what I'm lookin for after reading your post
) Then there nice chrome coil and some 11mm wire's...minor stuff but it should keep a super hot spark
| By thebige73@yahoo.com (Ejl2002) (66.84.137.106) on Wednesday, June 22, 2005 - 12:06 pm: |
I just recently installed a petronixs kit, took about 7 minutes to instal, and worked just fine. Only 2 wires to connect. Mine was for a 75 cvcc ED-1, but it should be the same. I think the part number was 1741, but I would double check.
| By nathan (24.85.232.159) on Wednesday, June 22, 2005 - 10:40 am: |
I checked out the pertronix gear...any reviews from anyone?
I was also originally going to use a EN electric dizzy...but this was recommended...
| By Glenn Biscan (211.30.144.154) on Wednesday, June 22, 2005 - 05:23 am: |
my auto elec wired mine up with new leads, new coil for $170 worth every cent
| By Adrian (Evocivic) (203.42.97.141) on Tuesday, June 21, 2005 - 08:58 pm: |
There are only a handful of wires to splice in, plus the igniter and it's done. Much better and more reliable than points. How to do it has been covered numerous times in the past.
| By Tim Calvert (69.11.53.195) on Tuesday, June 21, 2005 - 08:49 pm: |
You are right to much electronics for me to deal with shut offs etc. You have any suggestions?
| By Adrian (Evocivic) (203.42.97.141) on Tuesday, June 21, 2005 - 06:54 pm: |
I don't understand ... are you saying you put an EN engine in a 76 and you aren't going to use its electronic dizzy but rather the old points dizzy? Is it because you can't work out how to wire up the proper one?
| By Tim Calvert (216.197.185.73) on Tuesday, June 21, 2005 - 06:48 pm: |
Have an en electonic dist. as swapped en engine to a 76 civic that could not use so it is for sale Swift Current Sask Canada.$50 plus freight includes cap rotor etc
| By Bryan (66.32.246.165) on Tuesday, March 15, 2005 - 06:01 am: |
I am looking for a good condition EN electronic Dist. Any help would be appreciated.
Bryan
