| By Parker (12.173.142.61) on Thursday, April 28, 2005 - 07:52 am: |
i know i like to use coarse stones to get a good quick seat on my later model hondas. 120 grit.
always make sure it is lubed though, and i always hose off the cylinders with brake cleaner and wipe the cylinder walls with rubbing alcohol soaked paper towels until they dont pick up any more dirt/shavings. then wipe em down with wd40
| By Robert West (68.96.220.197) on Tuesday, April 26, 2005 - 04:34 pm: |
I agree! 320 is hard to beat. Try to put a 30 degree up and down on it, then scrub it with Scotchbrite to remove the grit. Works like a champ ;)
| By bruce (63.26.102.144) on Sunday, April 24, 2005 - 07:11 am: |
best thing to do is get a honer....lube up your cylinder and go at it, just a few things, don't stop the hone in one place while you are honing, keep it moving. and it does not take but a minute or 2 to usually do each one, some parts stores rent them.
| By yellowcivic (209.63.196.142) on Sunday, April 24, 2005 - 04:26 am: |
OEM rings are chrome top and cast on the lower. I would use 320 to help the rings to seat.
| By Jdupre (Jdupre) (24.5.152.32) on Sunday, April 24, 2005 - 12:01 am: |
What is the proper "grit" for honing cylinders for use with "standard" rings on the E series engines? The service manual for the EF1 says to use "fine", but how does that translate to 280, 320 or 400 grit?
A generic "performance" engine building book I have recomends 400 grit for cast-iron or moly rings, and a more coarse grit if using chrome rings. What kind of material are the OEM rings made of?
