| By Yellowcivic (67.138.127.210) on Tuesday, May 03, 2005 - 05:30 am: |
The trans are interchangable with no mods.
| By Simmo V (202.7.202.2) on Tuesday, May 03, 2005 - 01:59 am: |
just wondering if you knew if a gearbox from a eb1 can be bolted onto a eb3 engine???
| By Simmo V (202.7.202.2) on Tuesday, May 03, 2005 - 01:56 am: |
| By Justin Kehler (Justink) (205.200.31.69) on Monday, May 02, 2005 - 08:59 pm: |
I haven't taken both out to look, but I assume they can be swapped. The part number is different however. Different ratio maybe? Part # for 77 wagon is 53040-663-672, and for 78 1200 is 53040-634-673
| By H (24.70.95.204) on Monday, May 02, 2005 - 04:44 pm: |
I believe the rack is the same.
| By Justin Kehler (Justink) (205.200.31.69) on Monday, May 02, 2005 - 04:39 pm: |
Anyone? the beam I can fix, but I'd like to use the steering rack from my 1200 if possible.
| By Justin Kehler (Justink) (205.200.62.141) on Sunday, May 01, 2005 - 12:33 pm: |
ah crap. Oh well. Looks like down time for the wagon. How about the steering rack?
http://www.warezstein.com/~justin/cars/rear.jpg
http://www.warezstein.com/~justin/cars/wagonside.jpg
| By H (24.70.95.204) on Sunday, May 01, 2005 - 11:36 am: |
They are different.The wagon support beam has a additional mount that the 1200 does not have.Also the bolt configuration is different.I have modified a wagon support beam to fit a 1200 so It could be made to work from 1200 to wagon but will require some cutting/drilling and welding.
| By Justin Kehler (Justink) (205.200.62.141) on Sunday, May 01, 2005 - 10:41 am: |
Can I use the rear engine support beam (the one that always rusts out) and the steering rack from my 78 1200 on my 77 wagon? I know the parts #'s are different, but I don't see why they couldn't be swapped.
