| By Colza (Colza) (219.88.58.177) on Thursday, May 05, 2005 - 04:09 am: |
That all seems correct as far as what we get in NZ, and that should cover all European models too?
Except that our 1500's are non-cvcc. I think they should be referred to as 1500's, cos the cvcc and non-cvcc variants are the same apart from youre silly emmisions rubbish =P
| By Zauster (209.89.214.148) on Wednesday, May 04, 2005 - 09:23 pm: |
Correction - the exhaust and rad may not work if you are outside North America. I remember something to this effect but not sure on the details.
David
Edmonton, AB
78 1200
| By Zauster (209.89.214.148) on Wednesday, May 04, 2005 - 09:16 pm: |
Here are just a few most common ways to tell: If no markings including the dash on woodgrain, rear emblems, grill stating CVCC and if the steering wheel has been replaced (2 spoke 1200, 3 spoke CVCC), you can tell by the engine - exhaust out the front for 1200, rear of head for CVCC. If there is a small rad and no sheet metal beside the rad covering the rest of the front, then a 1200. Also if your front valance can be unbolted from the car and not welded on, then it is a CVCC. Also different rear suspension.
Now with the year, the easiest way to tell is to look for the blinkers - below the bumper with plastic corners 78/79, above the curved chrome bumper 73-77. This works in North America but not 100% sure around the globe.
Hope this helps, as I assume you mean the 1200 versus the CVCC models.
David
Edmonton, AB
78 1200
| By felipe casanova (200.74.71.222) on Wednesday, May 04, 2005 - 02:24 pm: |
are you from chile?
| By Justin (199.60.112.10) on Wednesday, May 04, 2005 - 12:39 pm: |
open the door, and look at the tag, it will tell you the year, where do you live?
| By Maestro (Maestro) (62.135.90.19) on Wednesday, May 04, 2005 - 12:08 pm: |
also the model pleas case some told me that it is 1977 not 1978
| By Maestro (Maestro) (62.135.90.19) on Wednesday, May 04, 2005 - 12:06 pm: |
i know that there is some experts here knows.i want to know if my car a cvcc or not it is 1300 cc looks like that one in this page but it has 5 doors.
http://zauster.com/civic1200/exterior.htm
