| By Adrian (Evocivic) (203.42.97.141) on Sunday, May 15, 2005 - 09:35 pm: |
Similar, but not the same. The GL1000 carbs are basically the same body but with different float bowls, without the economiser valves. Similarly the Mugen quads are the same body but also don't have the economiser valves (whatever an economiser valve actually does
| By John S. (66.143.33.125) on Sunday, May 15, 2005 - 09:13 pm: |
Those are the same carbs as on a GL1000 Honda motorcycle, though the jetting IS vastly different...you might have better luck hunting the parts as pictured from the Motorcycle angle as the RS carbs were never imported Stateside in Honda Automobiles.
| By jim_mac (211.31.38.187) on Sunday, May 15, 2005 - 08:51 pm: |
I thought I would get more response. I sent a e-mail to rage performance - no reply yet.
Guys someone must have some bits or the whole carb to sell. please have a look. here's the missing economiser valve bits -
thanks Jim
| By yellowcivic (70.97.64.135) on Thursday, May 12, 2005 - 06:17 pm: |
You might try these guys. www.rageperformance.com/carberatorparts.asp. Also the kehnin 3 barels used that accelerator diaphragm.
David
| By jim_mac (211.31.1.8) on Thursday, May 12, 2005 - 05:44 pm: |
I've been lucky to find a set of RS Keihins and manifold last week.
The carb on the right is missing the economiser valve kit which is a spring, diaphragm and the cover - see the picture below. I also want a accelerator kit as the one installed has a bodgey diaphragm and plunger.
Can any of you guys help with these bits or direct me to a supplier?
thanks Jim
