| By natcho (208.195.243.194) on Wednesday, July 06, 2005 - 02:51 pm: |
So does First Interstate.
| By Twyla (154.20.208.98) on Wednesday, July 06, 2005 - 08:57 am: |
Optima makes the smaller batteries
| By sonymmx200@aol.com (68.7.165.149) on Tuesday, July 05, 2005 - 09:48 pm: |
Unfortunately, I've been using a bigger battery from Costco. It barely fits on the spot, but I managed to get it in there snug. For some reason having an overhead console with a clock wears down the battery, so that's why I got a bigger one. Now my new problem is that my alternator doesn't charge the battery enough. I'm running a 30amp alternator and I'm upgrading to the 45amp that's used with the AC unit. I have PIAA lights, super white modern headlights, 600 watt amp, MP3 stereo with 200 watts, internal fan and cell phone charger. Hopefuly running a 45amp alternator helps. I'm also installing a new voltage regulator. Anyone ever run a 45amp alternator on a NON-AC CVCC 1500 engine?
| By jms (68.19.246.231) on Tuesday, July 05, 2005 - 07:14 pm: |
I cant seem to find those small batteries anymore that originally cmae in the car, walmart doesnt caryy them now, so anyone know the cranking amps or where to get that small stock bettery?
| By Darrell--Arizona-- (68.109.151.121) on Monday, June 06, 2005 - 02:26 pm: |
Its usually located on the battery label.
| By jms (143.79.13.6) on Monday, June 06, 2005 - 05:02 am: |
how does one determine cranking amps?
| By Darrell--Arizona-- (68.109.151.121) on Sunday, June 05, 2005 - 12:42 pm: |
I think the civic will be ok as long as the battery is big enough, but I'm very concerned that the tractor won't start.
Seriously....if you have long cables going to your starter, you should increase the size of your wire so you can get full power to your starter. Longer wire has more resistance so you have to increase the thickness.
If the cranking amps match on the new and old batteries, and your wires are thick enough, you shouldn't have a problem.
| By jms (68.19.233.134) on Sunday, June 05, 2005 - 11:13 am: |
Will it have enough juice when the time to relocated comes, anyone use such a battery before will it cause any issues?
