| By John S. (207.160.168.243) on Thursday, June 23, 2005 - 12:49 pm: |
Early Civic (74-77) is a lot different from "78-79 wiring...it will be some work to do it.
| By Hugh Johnson (Oneson1) (144.138.198.223) on Thursday, June 16, 2005 - 04:39 pm: |
hoboy, thanks for that. I was hoping not to have to stuff around with too much wiring :D
hugh
| By Justin (24.69.255.203) on Thursday, June 16, 2005 - 08:29 am: |
you need to swap out the lower bezel that surrounds the steering column aswell. the plugs do not interchange, it's best if you were to grab the whole dash harness and graft the two together
| By Hugh Johnson (Oneson1) (144.138.198.120) on Thursday, June 16, 2005 - 03:11 am: |
Hi, does a later model column (76 or later) with column mounted light,wiper and indicator stalks bolt into/plug into a 1974 civic. are there any under dash relays etc to gather as I salvage the column assy.
hugh
